Question about Sharp Televison & Video
Sharp LC50BU30U LCD-LED TV with no picture. In a dark room you can see menu screen. Im getting 56dcv at both LED pins and 86dcv at Vout pins. Sound like power board or just damaged/dim led strips?
Posted by Vinny I on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: No picture and no power LED
Hello. I have the exact same tv. and the same thing happened to me! What i did was buy a expensive Surge Protector and now it works! I hope this info is useful!
Posted on Apr 20, 2008
Anonymous
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
SOURCE: No Power - Viewsonic N3252w LCD TV
you go to a service centre near your area who repear it
Posted on Sep 08, 2009
satavlad
Alex Zoubkov
  • 405 Answers
SOURCE: Sharp AQUOS LC-46D85U green LEDs blinking, no picture, no sound
Sharp warranty is the way to go.
Posted on Oct 25, 2009
Anonymous
  • 255 Answers
SOURCE: Power Button wire to mother board power led power
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Posted on Nov 25, 2009
My samsung 62" tv has no picture/have sound
Darken the room. Very dark. Turn tv on. Press menu button. Get flashlight and shine at screen. If you can make out the menu barely. It's the back light gone. Is it plasma or lcd.
Jan 01, 2018 | Samsung Televison & Video
When I turn on my Sharp TV the picture comes on for a second then goes black. The sound is working but the picture stays black.
hi quick test, in a dark room shine a flashlight on the screen, if you a can see an image, bring the menu up if you can see it the led or leds in panel may blown, thanks
shaun
Feb 15, 2017 | Televison & Video
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
My sharp model lc-20b9u-sm has a dark circle on screen
Without seeing the dark cycle myself it is difficult to guess what. I only can think of something hit the screen (ball?) or perhaps someone bumped into the screen?
If the bump was minor, it could become lesser.
Perhaps you should ask a technician to look, or take a picture from the screen, one when switched on and one switched off, but close to where the dark circle is and take the pictures to a tech.
Jun 26, 2014 | Universal Premium Wall Mount For Model...
My sharp tv lc-20b9u-sm there is a dark circle on screen when there is picture or antenna off
Can you include a picture of the screen here; Johson? If so, it will be more helpful to provide a solution to this problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
New Toshiba 32'' - sound gone funny
on your remote control click menue and than select sound and go from there
Oct 16, 2017 | Toshiba CX36F84 TV
Televison & Video Logo
55 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
