I need a timer
Model # wpror1000.Date code 3713
Posted by Kat Horner on
How do I set the date and time on yardworks model #59-3531-0 watering timer?
how do i set the date and time for yardworks model # 59-3531-0
Jun 01, 2011 | Garden
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
E70 error code
You didn't include the model number, but it sounds like a ricoh FT3213 or 3713. If your not a tech, and it sounds like your not, then you'll need to call one. The waste toner is located in the cleaning section, and it needs to be emptied, and then reset in service mode with "SP83" which will mean nothing to you.
Apr 03, 2009 | Office Equipment & Supplies
Error codes
Try to check the fuser section.
- Check the Lamp
- Check Motor Assembly
Sep 12, 2008 | Ricoh FT5832 Copier
Vivitar ViviCam 3713
http://www.driversdown.com/Download.asp?ID=27071&Url=http://down2.driversdown.com/Digital/V3355setup.exe
Nov 22, 2007 | Vivitar ViviCam 3710 Digital Camera
41 people viewed this question
Marvin
Marvin
