I need the latest dongle install 4DWin7DongleUpdate.exe file
SOURCE: Dongle won't work with 4D Embroidery
Unfortunately some people are having this problem when they are not properly installing the updates. It's important that when 4D is installed that you assign a particular port for your 4D dongle and always use this port when loading 4D. Have your dongle plugged in and access your configure menu. Click on Smart Update. Download updates into a file where you can find them. Follow the directions for each update. For the driver update, you must uninstall the current driver you have and then install the update for the driver. If installing the updates doesn't fix your problem, the only solution is to completely uninstall 4D and all of its components and then reinstall it. Sorry...but this has been the only way to fix it with some systems. Also, make sure your User Account Control is off before installing 4D.
SOURCE: 4D dongle doesn,t work on Windows 8.1. Need new dongle driver4rs ?
Information at link below:
4D Dongle not Recognized
Check the specifications on your sewing machine. Most machines have not yet been upgraded to use Windows 10.
