Question about Zephyr Kitchen Ranges
Okeanito grease Have unacceptable grease accumulation in my Zephyr Cheng Okeanito 36" hood, in areas that cannot be cleaned or accessed. What is my recourse?
Posted by Kevin McG on
Marc Natoli
I would try a hand steamer, it definitely won't affect the stainless and I'm assuming you have a large glass, stainless or tile cplashback. Hope this helps
Posted on Oct 21, 2019
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Posted on Feb 06, 2009
Anonymous
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at [email protected]
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Zephyr Typhoon control panel replacement
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: manual or instructions for accessing the grease tray
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: cleaning Zephyr Hurricane AK2636 kitchen hood
2answers
When I pan-fry steaks grease and moisture droplets accumulate on the circular silver safety grille rings on underside of my Zephyr Typhoon unit. Droplets even fall down on cooktop and cook!
You are using too much oil. Oil the steak and drop it into the hot pan. You can also use a spatter screen.
Grease Splatter Screen for Frying Pan 13" - Stops 99% of Hot ...
https://www.amazon.ca > Grease-Splatter-Screen-Frying...
Grease Splatter Screen for Frying Pan 13" - Stops 99% of Hot Oil Splash - Protects Skin from Burns - Splatter Guard for Cooking - Iron Skillet Lid Keeps Kitchen ...
Dec 11, 2019 • Grilling
Zephyr Savona has blue blinking light. What does that mean?
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
12helpful
3answers
How do I remove burned out light bulbs from zephyr range hood? What do I replace them with?
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
I hope this helps.
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
I cannot get my burners on my stainless steel gas stove top clean
What I would try. Assuming the "burners" means the cast iron assemblies on top of the stainless steel, remove them to an area outside. Perhaps on a piece of plywood, and clean them with oven cleaner. Grease may drip off them, so a deck or driveway are unacceptable. Wear gloves and watch splatters. Wash thoroughly with fresh water before reusing. Beware. Caustic chemicals can discolor stainless
spencer
1helpful
2answers
How do you change the bulb on Zephyr AK2100S ?
To replace the bulb you need to use a suction cup to grab the bulb then turn counter clock wise.
If you need the manual it is on the link below. Page 18
http://www.zephyronline.com/docs/brand_essentials/products/manuals/typhoona_manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
My Range Hood (Best by Broan K260A) is just two years old in a new house. WHen I use it, fat & grease drip down from the left and right edges against the wall. Can someone tell the problem?
grease accumulation, remove the fours screws on the lower plate, to remove excess grease. further you can unscrew the bolt that are holding the assembly and unplug the unit. after remove fans with allen key and remove motor , clean and reassemble , make shure to put motor the right back the same way. reassemble the same way , problem should be solve for at least 7 years depending on cooking.
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
3helpful
2answers
Range hood is making noies
Kitchen Ranges Logo
Top Zephyr Kitchen Ranges Experts
Dale Copeland
Dale Copeland
Vernon Taylor
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
