Question about Water Heaters
What type of replacement battery does a marathon tech clipboard use
Posted by Legge on
I cant get the water temp below 125 and I need to for our day care. I have the lower thermostat set to 110 and it still is 125 to 130 degrees. Is there something else I need to do. There is a upper...
You have marathon water heater?
Thermostat is probably bad. Has gone out of calibration.
Replace both upper and lower thermostats for $25 from local hardware store, takes about 20 minutes, turn off power, take photo of wires before starting. These thermostats can be adjusted all the way down to 90 degrees, and then dial up a bit to reach 110.
Copy following link for instructions how to replace thermostat yourself.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, then replace both elements.
Elements are special order made specifically for marathon.
Requires 1-7/8" socket to remove elements.
Upper 3800 watt, order part SP610130
Lower 3800 watt, order part SP210197
http://hometips.me/Mar/Rheem-Marathon-parts-2.pdf
http://waterheatertimer.org/How-to-replace-water-heater-element.html
More information about Marathon:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 26, 2013 | Rheem MR105245 Marathon Electric Water...
Rheem marathon vacuum valve
Copy following link for Rheem marathon parts and resources:
Add a comment March 2013 and describe problem in detail.
Mar 22, 2013 | Rheem MR50245 Marathon Electric Water...
Can I install 4500 wt elements in a marathon MR50238? The tank specs are the same as MR 50245.
1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
Older 3800 watt element models have been discontinued.
2) Copy following links for Marathon resources:
3) Product warranty is voided if element wattage exceeds label on side of unit.
4) Marathon has a problem with elements burning out frequently.
To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
Upper 3800 SP610130
Lower 3800 SP210197
Feb 20, 2013 | Water Heaters
Rheem Marathon Water Heater leak at pressure relief valve
Unless you are getting more than 150 PSI, you should just replace the valve. It has dirt in it.
Dec 27, 2012 | Rheem MSR50245 Marathon Electric Water...
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
My water heater wont heat up
You posted under Marathon electric heater.
If you have tankless or tank-type gas heater, information below does not apply.
Absence of hot water say upper element is not working.
1) This can be caused by tripped reset button located on upper thermostat. Open upper cover and push in reset button. Put ear against tank to hear bubbly fizzing sound. Put insulation and cover back over thermostat. Continue reading information below because reset button trips when thermostats are bad or element is shorted.
2) Upper thermostat is bad. Replace upper thermostat. I usually replace both upper and lower thermostats.
3) Electricity going to water heater from breaker box is interrupted.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Upper element is bad. Test element. Replace element if needed.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Rheem MR105245 Marathon Electric Water...
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
Just installed new marathon water heater and hae
check the water control valve to see if it is fully opened
Mar 07, 2010 | Water Rheem MR40245 Marathon Electric ...
Water Heaters Logo
149 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
