Question about Hifonics Car Audio & Video
I have a hifonics hfi1000.1d im trying to hook up 2 kickercomp cvr12 iwant to bridge them and run them in series
Posted by mark knapp on
5 Related Answers
Anonymous
  • 77 Answers
SOURCE: sub making horrible thumping garbage sounds
you need an noise filter in line. It's been a few years since I've had a system but I had the same problem. High power amps like the one you have can actually pick up on the electric pulses from your ignition system. I think I got mine at walmart, or auto zone, somewhere like that. Their pretty cheap too. I don't remember how its hooked up, but If you know how to hook and amp up, this should be no problem.
Posted on Jun 23, 2009
Anonymous
  • 52 Answers
SOURCE: bridging amp/sub
wire speakers in series google it to find diagrams
Posted on Jun 30, 2009
Shawn
  • 112 Answers
SOURCE: PHOENIX GOLD RYVAL V1502
Most the time want happens is the postive wire is not the right gauge or the amp cant handle pusing two speakers you m have to put in two amps try hooking up one sub and see want happens if it dosent die out the amp not strong enough for the 2
Posted on Jul 08, 2009
robotek
Graeme Ross
  • 1512 Answers
SOURCE: can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Posted on Jan 19, 2010
Testimonial: "Thanks for the help should i just leave it 4ohms how do i wire it like that? "
brandon day
  • 173 Answers
SOURCE: I hooked my Hifonics BXi 1610 Brutus series
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
Posted on Mar 21, 2010
If i hook up for 2 ohm do i use one speaker wire off amp bridged
Just use both speaker outputs, no need to bridge them,
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Im trying to run two kenwood 6/9,s and a mtx sledge hammer 12'' sub of a mtx 6004 amp.where do i put my rca,s front or rear / and if this is poss how do i bridge the sub ????? im lost
Im kind of confused with what exactly your asking. Are you trying to run 3 subs off of an amp? If so, the RCA's should go to the front of the amp, and if your plugging 3 subs in to it, you need to have a 3+ channel amp. There is a way to hook it up differently though. I have 4 12" Hifonics subs running off a 2400 watt Nitro-BMW-486 amp. I just have two subs running to each of the two channels.
3answers
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
I have a Hifonics BXI1208d mono subwoofer amp but i have 2 sets of wire terminals and they go negative negative postive postive. Which do I use?
Depends if its bridgeagle or bridge internally. bridgeing provides the most power to a mono system. 2 positives and 2 negative you have a 2 channel amp. Heres a link to check out, you should be able to figure out your system and hook it up with this. Hope it helps. http://www.wikihow.com/Bridge-an-Amplifier
2answers
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
1helpful
3answers
Hifonics bxi 1206d
make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
#1 SPEAKER #2 SPEAKER
WIRE WIRE
ONE GOES ON THE POSIVE OF ONE SIDE AND THEN THE NEGATIVE OF THE OTHER
HOPE THIS MAKES SINCE
PLEASE LEAVE MY RATING
Car Audio & Video Logo
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Admin UK
Admin UK
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
