It may be a problem with the damper panels that are situated between the freezer and the refrigerator. Most people note a problem when the damper doors stop opening and food becomes warm. In your case the doors may be not closing properly.
This may be mechanical, the damper louvers assembly is broken, or it may be electrical, the relay switch and motor assembly that operates the damper is not operating properly.
In side by sides the damper is usually in the upper side rear of the refigerator. If you can peer into it, you may be able to see light from the freezer (freezer door open) which would confirm the louvers are open.
Quick fix? duct tape a portion of the opening. It will restrict cold air flow. Costs little, and if you are not particular will work. Other fix. Call a repair man and be prepared to pay about 200 for the parts and labor.
Aloha
You just need to clean the coil located under the fridge
