Question about Elna Sewing Machines
SOURCE: My bobbin cotton wraps around the bobbin holder and jams the machine
I know this is probably not the answer but: are you sure the thread is coming off of the bobbin on the left side (bobbin in machine correctly), and when I first got my machine I tied to use the bobbins that I had on hand that fit my Singer machine. I had tons of problems with the "odd" bobbins that did not fit correctly into my machine. There is a VERY small size difference, but it does make a difference.
joanne
Posted on Jan 02, 2008
SOURCE: bobbin winder wont engage properly
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hope it may helps you;
Regards,
VOTIT
Posted on Sep 19, 2008
SOURCE: thread gets caught on the bobbin holder and won't
Hello there:
have you tried to adjust your stich pattern and slowed down your feed rate also doublecheck the bobin to ensure that it is installed fully in the casing and is not warped at all ok?
regards mike
Posted on Aug 18, 2009
SOURCE: cannot remember how to thread bobbin elna
i solved the problem after i had a closer look at the top of machine
Posted on Feb 21, 2010
SOURCE: How do I time my Pfaff 1222E
I could write up the procedure but it would be too much for me to type in. Or you can purchase the 1222E Repair Manual and download it. It's pretty easy to work on as long as you have similar tools to clearances.
Posted on Apr 11, 2010
Sep 10, 2013 | Elna Sewing Machines
Sep 17, 2011 | Elna Quilter's Dream 6003Q
Jun 16, 2011 | Elna Sewing Machines
Jun 08, 2011 | Elna 1010
May 09, 2011 | Elna Sewing Machines
Apr 21, 2011 | Elna Sewing Machines
Apr 11, 2011 | Elna Quilter's Dream 6003Q
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, it looks very similar to this Elna so I'm thinking its the same design bobbin and race. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.
Mar 07, 2011 | Elna Xplore 8600 Computerized Sewing...
May 17, 2010 | Euro-Pro 473
Mar 31, 2017 | Euro-Pro 9125 Computerized Sewing Machine
126 people viewed this question
