Question about Food Mixers
HL600 problem. After 15 min mixing the display on the control panel stopped working. No lights at all.
Put another control panel. Same thing. Worked for like 15-20 min and lights went away again. So I put 3rd control panel on it. Same thing. Worked for a while and lights went away. Bowl goes up and down. Mixer wont start mixing. No lights , no error codes, nothing. Please help. Thank you in advance.
Posted by Stoyan Velichkov on
5 Related Answers
Anonymous
SOURCE: bosch universal mixer
Sounds like the belt came off when you tried to mix the frosting while it was cold. Just too much of a load. It will have to be taken apart and the belt put back on.
Posted on Aug 29, 2008
Anonymous
  • 16 Answers
SOURCE: Mixer goes really fast then stops
First thing, check the Hall Effect Sensor (part # 9703312) to make sure that it is seated snugly AND properly!  The Hall Effect sensor measures the speed of a tiny rotating magnet and basically tells your mixer how fast it should rotate.  I was experiencing the same problem that many others have described here--my mixer would go really fast no matter what speed I put it on and it would shut off after five seconds. I came to the FixYa site and saw that one solution that seemed to work was to replace the Hall Effect sensor.  So I went to a local hardware store and purchased a new Hall Effect Sensor for about $13.  After I replaced the "defective" sensor, my mixer still did not work.  So, I started experimenting with the three prong orientation of the control board--this can make a big difference. After a little trial and error, I found the correct orientation for the sensor and my mixer worked good as new!  But I was curious to see if the improper orientation was the cause of my original "defective" sensor.  So I put the "defective" sensor back with the proper orientation and THIS ALSO FIXED MY SPEED PROBLEM! There was nothing wrong with my original Hall Effect Sensor at all--it simply was not snugly or properly seated!  I'm not sure how it happened--possibly over time the sensor prongs may have become unseated from the vibrations of running the mixer on high speeds--but my original Hall sensor was not seated properly or snugly.  So before you run out and buy a new Hall Effect sensor make sure that the original one is not only snugly seated but also properly oriented!  If I knew how to add digital pics, I would have put pictures in my comments to clearly demonstrate what I found.  Unfortunately, I am not sure how to do this.   To sum this up: 1. Download the parts information and diagrams from the Kitchenaid site and find the Hall sensor (part # 9703312).  2. Make sure that the Hall sensor is firmly attached on both ends.  The actual sensor should be located next to a tiny magnet and this end needs to be securely seated.  And the other end of the Hall effect sensor has three small prong holes which also need to be firmly and corrected seated to the control board! Bottom line, my mixer is working like new and I put the original Hall Effect sensor back in the mixer. I'm going to hold on the new one as a backup...you never know.
Posted on Dec 30, 2008
bigg t
anthony james
  • 640 Answers
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
paultech8226
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
Anonymous
  • 110 Answers
SOURCE: how to adjust bowl height on 20 qu hobart mixer.It
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Posted on Jan 19, 2010
Brand new Kitchen Aid. Loose Bowl,
go talk to the place you bought it .
Dec 09, 2017 | Food Mixers
My Kitchenaid Mixer stopped working. Saw a mention of replacing the thermistor? Or is it the motor or control panel?
Make sure that the carbon brushes are not worn out or if you have already had them out make sure that they have been put back in properly. There is one corner ground off each brush that needs to line up with a blocking corner in the brush holder. Then get your multi meter out and check the unplugged main cable for continuity to the speed control panel. Then check each half of the field assembly for continuity from the speed control plate to a brush holder. Check you have no broken wires to the speed control plate. Check that the switch on the speed control plate is functioning. If all that tests OK I'd replace the phase board, it's worth not much and worth a shot.
Jul 28, 2017 | KitchenAid Food Mixers
JennAir Attrezzi dead, no light, no nothing. Was working. What do I need to do?
Replace the fuse located below the plug inlet on the mixer, you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Oct 11, 2011 | Jenn-Air Attrezzi JSM900 Stand Mixer
Hi there, I was doing cake mixing and turn off
If you can hear the motor spinning and the beater does not spin, the worm gear has probably failed. These fail frequently, specially after using them beyond there designed limits. The motor heats up and the gear, which is a type of plastic or nylon, melts.
Feb 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
Whats does b_9d mean. My mixer wont start to mix. The power is good but it tels me b_9d.
that fault is a b_gd.there are 10 things that can cause this.1.start sw.momentary contacts not closing. 2.stop sw. contacts open. 3.bowl guard sw. open or malfunction(b_gd)displayed on timer.4.contactor 1con malfunction.5.timerboard malfunction.6.wiring incorrect from sr drive to motor or 1con.7.sr drive malfunction 8.1 con monitor from control drive disconnected from contactor coil9.encoder malfunction 10.motor malfunction. hopefully just your bowl guard switch is no good. hope this helps, dont forget to vote, monomoy
Feb 01, 2010 | Hobart HL600 Legacy Stand Mixer
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 | Food Mixers
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
Food Mixers Logo
143 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
