I have a 1995 Ford E-250 van and I was told that the neutral safety switch may not working. I need to know how to locate the switch.
Neutral Safety/Back-up Light Switch
This is a combination switch which controls both Neutral Safety and Back-up lamp circuits.
C6 Transmission
C6 neutral start switch
AOD Transmission
Removing the AOD neutral start switch
Removing the Manual Lever Position (MLP) sensor
As of 1994, the neutral safety switch is referred to as a Manual Lever Position Sensor (MLP).
To install:
ADJUSTMENT
C6 Transmission
4R70W Transmission
Adjusting the MLP sensor
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
I hope help you. Good luck (rated this help).
How do i replace the rear bumper on a 2004 ford focus sedan
On a 1976 class c GMC Motorhome where is the neutral safety switch located?
Car will not start I was told to disconnect the neutral safety switch on my 2004 Chevy trailblazer where do I find this
