Question about Garden
How do you hook the throttle linkage to the carberator on 2050 johnsered ?
Posted by Wanda-Gordon Knorr on
4 Related Answers
Ted Schore
  • 7353 Answers
SOURCE: need to hook up the throttle cables to the
Usually if you look at how they clip on to the bracket, they only go 1 way.
Posted on Dec 18, 2009
wadingriver
wadingriver
  • 2223 Answers
SOURCE: I have a new carberator for model # 331777 1372
It might just be a single idle screw to adjust.. not familiar with the Model.
Posted on Sep 16, 2013
emissionwiz
Marvin
  • 85239 Answers
SOURCE: huskee riding mower missing linkage from throttle to carberator
Contact a retailer of mower for parts, we do not sell parts here.
Posted on Nov 18, 2016
Bill Boyd
  • 53814 Answers
SOURCE: I have a Poulan lawn tractor, Model # PB22H46YT. I can't get the linkage set properly along with the governor linkage? I've been looking for picture of carberator throttle and the governor setting
the throttle linkage and governor setting will be found in the workshop manual for the engine that you have
so
search --workshop manual for ( engine make and serial /model number) and down load the pdf version
Posted on Jun 28, 2018
Cleaning carberator
There are various way to clean your carburettor:
First, buy a can of carb cleaner spray.
Start your engine.
[1]: Remove air filter and squirt cleaner into venturi, revving engine via throttle linkage (at carb) to avoid stalling.
[2]: Remove fuel inlet hose from carb and squirt cleaner directly into inlet.
Otherwise:
[3]: If very dirty, the carb may need to be removed by a mechanic and sent in to a professional company for service.
Jul 25, 2018 | Cars & Trucks
so
Jun 28, 2018 | Poulan Garden
Huskee riding mower missing linkage from throttle to carberator
Nov 18, 2016 | Garden
Connecting carburetor to the throttle on husqvarna 44 chainsaw
The wire linkage has a short Z bend in one end this hooks into the throttle lever from the outside, the other end has a long loop this goes into the trigger arm from the outside, you will need to twist the top of the trigger arm slightly to allow the linkage to go into the hole in the trigger arm.
Dec 29, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Can not get lawn tractor to idle in the high setting. Think it may be the carberator. How do I clean it and the throtle body?
Go to an automotive parts store a get a can of GUNK spary carb cleaner. Spray directly into the carb and spray the throttle linkage as well. This will loosen any junk that's causing sticking.
Sep 17, 2010 | Garden
Car wont idel and revs some times for no apparent reason its a hyundai xl 1995 duz it sound like the iac valve
If it has a carberator check to make sure that the throttle linkage is in a relaxed position when the car should be idoling in other words if the linkage is too tight then while your gas pedal may not be pressed the linkage is so tight that it is still pully on the throttle linkage and causing it to rev. The only reason i can think of it revving on its own though is maybe a tension spring on this linkage is broken and the linkage is loose and flopping back and forth from idel to throttle with bumps and other distrubances.
Aug 04, 2009 | 1994 Hyundai Excel
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Apr 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
