Question about Mitsubishi Televison & Video
I HAVE A Mitsubishi Big Screen TV Model VS-6051 WHY IS MY PICTURE RED AND BLUE?
Posted by Sandy Gus on
5 Related Answers
Anonymous
SOURCE: Mitsubishi VS-5059 50 in. Proj. Televsion
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. This should not be an expensive job at most repair shops. Could be something as simple as cracked, cold, defective solder joints around and near the vertical output chip, could be a faulty chip and other components in and around the vertical deflection circuitry, or a faulty vertical drive signal from the jungle circuits, or worst case a faulty deflection yoke. Take your television to a shop right away for a proper and safe repair. Do not keep the television looking at the red horizontal line.... you can easily damage or burn the CRT phosphors. Good luck
Posted on May 29, 2006
Ekse
  • 13434 Answers
SOURCE: MITSUBISHI TV VS-60607
Do you get any power indicators? it may be a problem in the powersupply area, or something more serious. Start with checking the fuses there.
Posted on Jun 07, 2008
joekuol
  • 3 Answers
SOURCE: no picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Posted on Aug 16, 2008
Anonymous
SOURCE: MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Posted on Nov 25, 2008
shaun taylor
  • 1527 Answers
SOURCE: Mitsubishi Big Screen TV Model VS-6051 will not
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Posted on Sep 20, 2009
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have a bow in the top of the screen for a Mitsubishi vs-6051
Call a good TV Tech and tell him the problem is the convergence amp IC's are bad and need replacing. This should not cost over $325
Jul 28, 2009 | Mitsubishi VS-6055 60" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Problems with a Mitsubishi Big Screen
Where did you adjust the red and blue?................Did you remove the speaker grill cover and the access panel to get to
the screen control adjust? Do not adjust focus..........make
sure you turn down ( CCW ) the red screen control a little....
is that any better...........?...................T.
Dec 03, 2007 | Televison & Video
1998 mitsubishi big screen tv model vs-50603
Good Day, bigjim;
No inner tube. The tube may light up but it no video bias to turn the tube on, or the tube is so gassy that it doesn't emit properly.
It sounds like you will be in the market for another TV, because it sounds like like the CRT may be bad.
Hope this was helpful and not tooo late.
Good Luck, big IRISH.
Dec 30, 2006 | Mitsubishi WT-46805 46" Rear Projection...
VS-6051 fuzzy picture
Those three Knobs were the focus or screen controls . your problem may be dust and dirt on the lens or the tubes could be getting soft. It could also be a convergence trouble and thats very common in these sets . a picture would be nice see where your problem lies BUT let me warm you down there where you were plying and turning those little knobs is about 32000 volts!!did you know this ? A tv set is not something to experiment with as it could kill ya. Unless you have technical background in electronics I would call a servicer to assist you. Good Luck
May 26, 2006 | Mitsubishi VS-6055 60" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
