The 12v & 240v switch is to change voltage supplied to the camper. You use the 12v if you are running things from the battery; you use the 240 when you're connected to what the US calls "shore power" or "land power"
The hayni made in china internal power supply has faulty transformers on it that fail within anywhere from 6 months to 2 years. Solution. Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box and it only cost 15 dollars. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. Now my wine cooler is more energy efficient and and will run for at least 5-10 years. This power supply replacement takes about 20 minutes. You need: philips screw driver, wire cutter and stripper, two 16 guage wire nuts. That's it.
Try a computer repair store, or go online to Audiosonic to see if they can provide the part, finally! www.ebay.com Type: make and model, or the power supply number.
