Question about home Audio Players & Recorders
I've got a problem with my home theatre HT-c450 model when I swich on it says protect mode and it goes off
Posted by Luckson Bangie... on
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: Protect error
This is a failure of the power supply or the amp. In either case, this unit is one that the boards are available and should be replaced. The first thing you must determain is which board is bad.
I have been repairing these since they started making them, and can tell you that it is not an easy task to figure out which board is bad. You will need a multimeter, and then know how to use it very well.
Sometimes you can get pointed in the right direction just by knowing what was happening when it went bad.
If the unit was working and you turned it off, then the next time you went to turn it on you started getting the "protect" message in the display, you most likely have a bad power supply board.
If you were listening to the system and it just shut off on you and then when you turned it back on you got the "protect" message, then it is most likely the amplifier board.
There is one more thing to check before you ever buy a board for this unit. If the fan in the back is not turning when you turn the unit on, it may only need a new fan. Lets hope that this is your problem, it is cheap and easy to fix. The other options may be better for you to take it to a service center to properly troubleshoot The boards are a little expensive, but that is what Samsung does with these units, they replace the boards. Most all other audio equipment from all other brands do not even make the boards available.
Check the fan first, if you need the part number let me know, I think I may have a manual to look it up for you. If you want to try and check the boards, I may be able to help a little more, but this is a very difficult thing to do over the internet.
I would appreciate it if you would wait until we are finsihed communicating on this problem before you rate it.
Thanks,  Dave
Posted on Jan 22, 2009
Anonymous
SOURCE: my dvd home theatre system ht tx75 keeps shutting down
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Posted on Jan 28, 2009
Anonymous
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Posted on Apr 14, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Anonymous
SOURCE: Samsung Home Theatre "Protection Error"
i've had a similar problem where the fan stopped moving and the system gave the usual "protect" error. i think the IC's burned out on the amp board since the error was no longer there when i unplugged it. i ordered a new board off ebey for $25 shipped. make sure this is the problem by unplugging both the power and data cables from the amp circuit (the board with the big heatsink) and starting it. if it says starts normally then the problem is the amp circuit
Posted on Sep 14, 2009
The home theatre system LG HT904TA went in to protection mode. Mean that the receiver/dvd panel shown 'protection ' on the display panel. I have try to switch off /on but the 'protection...
If you've disconnected the speakers and the fault is still showing then the fault is internal with the Amplifier and it's shutting down to protect itself from further damage.
Your only solution is to remove the cover and have a look at repairing it yourself or take it to a repair shop.
Jun 28, 2011 | LG Audio Players & Recorders
I have a LG ht502 home theatre , black and white only
Sir avservice, I have also posted a problem about an HT502 DVD receiver + Home Theater. The sound won't come out of the speakers but only of the Plasma tv. But was working before. And the word "PROTECTION" is appearing on the display screen of the dvd receiver. But good quality picture on the plasma tv. Please help
Jul 20, 2009 | Jensen JHT-350 System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
PROBLEM HOME THEATRE SYSTEM HTDS490
Hi, Ive had the same problem and after talking to Samsung Tech Support, I re-checked all my speaker wires and thier connection... one wasn't quite making proper contact so I adjusted it and PRESTO all better!!!!!
Sep 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
My DVD HT-Q9
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Sep 23, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
We are trying to watch a movie on our new ht-tx72 dvd home theatre system...but it keeps shutting itself off and saying protection goodbye....what can we do to fix this?...it is getting frustrating now
Your ICs audio amplifiers are in short circuit thats why that legend are coming for protect your theatre of more damage you got to replace the ICs.Good luck
Apr 13, 2008 | Televison & Video
46 people viewed this question
Top home Audio Players & Recorders Experts
Kenneth Walker
Marvin
Marvin
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
