SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
SOURCE: My remote control will not turn the fireplace on,
Clean the sensor on the unit, make sure no dust or ash on it. good luck
SOURCE: I just replaced the batteries in the remote
You didn't mention how many batteries you replaced. If it was only the 3 (AAA) in the hand held remote, you have 4 (AA) to go in the remote's receiver. It's the black box, inside the fireplace.
Depending on how long the batteries have been dead, the remote may have lost it's privacy/frequency code. In which case, it can be reset.
here is a link to your Owners Manual http://literature.mhsc.com/ambient/manuals/RCMT.pdf in case you have misplaced yours. You can download and print it, if you like. It will walk you through how to reset the privacy/frequency code. It has a Trouble Shooting Guide, that can prove invaluable.
Also, make sure the pilot on your gas logs or fireplace is burning and the Control Valve Knob is turned to the ON position. If it isn't, the remote control will not work
Hope this helps solve your problem.
SOURCE: muskoka electric fireplace ,the switch doesnt work
