Question about Kyocera Cell Phones
Purchased a kyocera c6743 that is screen locked and teied to factory reset but it wont go into recovery mode
Posted by Jamie Hutchins on
5 Related Answers
JAN_yuanjia
Antonio Buenafe Jr.
  • 470 Answers
SOURCE: how to factory reset a kyocera kx2 phone
go to the settings then chose the RESTORE FACTORY SETTINGS
Posted on Nov 22, 2008
Tim Digibrain
  • 846 Answers
SOURCE: Touch Screen is unresponsive.
If Verizon doesn't replace it for you, you can find the touch panel at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
Posted on Apr 26, 2010
mycharmingli
Stormi Paulk
  • 415 Answers
SOURCE: iPhone 3gs 16 gig. Black
Just take it back to the Apple store and they will replace the screen for you.
Posted on Nov 07, 2010
SOURCE: damaged screen so i plugged in a moniter but now windows wont operate properly.and the screen on the moniter wont load fast enough to launch safe mode or factory reset should i reinstall windows by ma
LOL a Recovery CD should be made when you first purchased the system. Now that you have it all bugged up, I would doubt that a Recovery CD you make now would even work. Most times the ones you make anyway don't work.
I think you should turn off the laptop, turn it on and immediately start hitting F8 repeatedly to get into Safe Mode. I've never heard of a situation where the monitor wont load fast enough to launch safe mode.
If that's the case it sounds like you need to fix the problem with the laptops lcd screen.
What do you mean when you say windows wont operate properly? I think you've got viruses or infections that you need to get rid of.
Posted on Apr 27, 2012
awaissabair
Big Boss
  • 580 Answers
SOURCE: factory reset u8150 without using recovery mode
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Nov 02, 2012
Kyocera model number c6745 how to reset
Hold down the Power key in order to switch off the cell phone.
In this step press and hold the Volume Down
+ Power button for a few seconds.
You should release held keys when the
Recovery Mode starts.
Afterwards press Volume Down a few timies
to highlight "wipe data/factory reset ", and
then push the Power button to confirm this
option.
Next, select "Yes--delete all user data ". Use
Volume buttons to scroll and Power rocker to
select.
6. When the Recovery Menu appears
on the screen, choose "reboot system now ".
Oct 11, 2016 | Kyocera Cell Phones
Why cant i hard reset my kyocera C6740
1. At the very beginning hold down the Power key in order to switch off the cell phone.
2. Press and hold the Volume Down + Power button for a few seconds
3. You should release held keys when the Recovery Mode starts.
4. Afterwards, press Volume Down a few times to highlight "wipe data/factory reset", and then push the Power button to confirm this option.
5. Next, select "Yes--delete all user data". Use Volume buttons to scroll and Power rocker to select
6. When the Recovery Menu appears once more on the screen, choose "reboot system now".
If this didn't work:
Go to "Settings", then-> "Backup & Reset", after that tap "Factory data reset", choose "Reset phone", and select "Erase everything"
Aug 11, 2016 | Kyocera Cell Phones
Did factory reset and now wont reboot just goes through diagnose and repair loop
If your computer did not have a recovery partition you would have had to make recovery discs. Was there a recovery option during boot process?
Sep 07, 2014 | Gateway Computers & Internet
Damaged screen so i plugged in a moniter but now windows wont operate properly.and the screen on the moniter wont load fast enough to launch safe mode or factory reset should i reinstall windows by making...
Apr 26, 2012 | Dell Latitude D520 Notebook
I forgot dhe/draw pattern to unlock my samsung boostmobile
i recently got locked out of my kyocera and i would like to know how do i re-set my phone.
Nov 22, 2011 | Cell Phones
Cell Phones Logo
90 people viewed this question
Top Kyocera Cell Phones Experts
efs_perpends
efs_perpends
David Gust
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
