Question about Element Televison & Video
Model ELEFQ462. Why doesn't it turn on? - Element Televison & Video
Posted by Charles Selby on
Tom Chichester
    Top Expert:
  • Element Master
  • 61,759 Answers
1. Open internal fuse
2. Power supply failure
Posted on Dec 24, 2020
Engine is not firing,motor turns over but doesn't seem to be firing
what year make model engine etc.................................
Feb 01, 2013 | 1994 Honda Accord
My display screen doesn't work and the camera turns on but would not turn off
Hello. Do not know the model of your camera, but sounds like system internal error. Try to download the firmware for your model at kodak website listed under support. Be sure to get only the file for your model camera !!!!!
Best Regards, Russell
Dec 16, 2012 | Kodak Cameras
Kenmore bobbin issues
try these suggestions
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Oct 25, 2012 | Kenmore Sewing Machines
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Kenmore upright Model 116 31912101 Brush doesn't turn. Little red reset pin doesn't move.
Something is jammed in it or the belt is bad.Turn it upside down.You will see 4-6 screws.Remove the screws and the plate they are holding.Now the brush is exposed.The belt hooks on to the brush and a small wheel on the other end.Remove the brush and belt.Make sure the area is free of debris.While you have it off,replace the belt.
May 16, 2011 | Kenmore 31913 Progressive Direct Drive...
Televison & Video Logo
Top Element Televison & Video Experts
ENFORCER
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
