Question about Panasonic Televison & Video
Unlock Panasonic pv d4743s dvd player region code with remote possible? thanks
Posted by len beauprey on
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: Region Code Unlocking for the Panasonic DMP-BD30K 1080p Blu-Ray Disc Player
Not all models have a known unlock hack, let see this one.
Posted on Aug 28, 2008
Anonymous
SOURCE: Unlock codes for Pioneer DVD player
Pioneer DV-667A
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Posted on Sep 16, 2008
Anonymous
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
Anonymous
how do I unlock my blu ray with factory remote?
Posted on Mar 13, 2009
ltfrc
Mike Schmidt
  • 227 Answers
SOURCE: multiregion unlocking code
Welcome to standalone DVD Player Region-free unlock guide. On our pages you will find a lot of verified working unlock codes collected from many different sources.
Whilst we made every effort to ensure that the information contained inside these pages is both accurate and up-to-date, we take NO responsibility and accept no liability for any damage caused from applying these procedures as laid down on these pages.
Use them at your own risk!
DVD Player model: Panasonic SC-HT80
Open CD drawer.
Press 9, 8, 1, 7 on the remote control.
Press ENTER till it shows region 9.
Press RETURN.
Posted on Apr 25, 2009
L need a multi region code for a panasonic dmr-ez47v.
Panasonic DMRs cannot be unlocked for muliti region simply by entering a code form the normal remote or front panle controls.
Panasonic machines require a special remote control in order to make them multi region. Panasonic dealers will unlock your machine for you but will charge you - this is expensive.
Alternatively, if you search eBay you will find devices that will unlock your machine that can be purchased or "rented", for considerably less than a dealer will charge.
Nov 07, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd player stopped working
NEED REPLACED DVD MECHANISM UNIT
Manufacturer Panasonic Part Number LSXK0118 Description MECHANISM
Sep 12, 2009 | Panasonic Televison & Video
I am in Australia and have just bought a DMR BW500. I have a dvd from Japan which won't work on it and I have been told that if I unlock the region code, then it will work. So how do I unlock the region...
The following works on a region 4 player. With no disc in the player and the drawer closed, press stop, stop, setup, then 3,8,8,8,3 and the desired region code, (0 for multiregion). Nothing will appear on screen. Then switch the player off and back on. It should now play discs for any region
Sep 04, 2009 | Televison & Video
Remote control arrow buttons suddenly dont select things anymore
Read page 36 of your users manual Its all under Manual Exposure
Please rate our help ++++
Thank you for using Fixya.com
Sep 01, 2009 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
I need the region dvd code for my panasonic triple play tv
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Nov 11, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Unlock region codes for portable dvd player - panasonic DVD LS80
Aug 04, 2008 | Car Audio & Video
Panasonic DMRES30V DVD Unlock code
Try This ..Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
Found at http://www.dvdhacks.co.uk/hacksearch/hacksearch.asp?player=PANASONIC
Jul 21, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Locked dvd
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Televison & Video Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
