Paper out error refuse tech acces - Office Equipment & Supplies
Posted by Oyebamiji Sunday on
Telkom has billed me with a YP 2016 Directory entry and refuses to reverse the charge
fixya has no access to accounts you can try notifying the provider and ask for a supervisor for explanation of refusal for refund
Sep 16, 2016 | Computers & Internet
Clear error message
clean the rollers for that draw or have them replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 07, 2014 | Konica Minolta bizhub Office Equipment &...
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
My Samsung scx 4x20 printer shows paper jam in the dsisplay but there is NO paper jam. Can not get the error away and the printer refuses to print. What to do?
I suppose that the exit paper sensor in fusing section is broken (ussually when you pull out paper jam you can brake this little black or blue pawl). You can order and buy only this paper sensor pawl (very cheep).
pifonski
Feb 23, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Canon Pixma MP160 doesn't take papers, looks like paper jam, but no paper jam in it. please how can I fix it.
take the printer and put it up side down, if you are lucky the object that bloks the paper acces will fall. if it will not fall you will have to take the printer to a tech.
Nov 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error code 5100 on canon pixma mx700
5100 says the carriage is not moving all the way across the paper path. There could be grease or ink on the encoder strip, the clear strip behind the carriage. Or a small paper scrap inside stopping the carriage.
Aug 09, 2009 | Canon Office Equipment & Supplies
Cannot get printer to work.
Greatings
I just want to let you know! that for fixing that problem you should call tech support and they are going to replace it for a refurbished printer, so for take that error message out you need to:
1. Unplug the printer from the power cord open the rear access door of the printer! and then you will see the roller you need to go on the third roller from left to right and roll it up like six times!,
2. closed the rear acces door and open the front acces door try to move the carriege of the cartridges to the midle!
3. take the cartridges and the printhead out
4. close the acces door plug the printer back in and then it will ask you for the printhead and the cartridges
So you just need to insert them back in! But this time make sure you insert that pritnhead properly because that error message was causing for that printhead in bad possition
Regards
Jul 23, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Marvin
Marvin
