Question about Garden
My sthil ms 200t runs at full throttle only but dies when finger is off trigger new carb and fuel filter
Posted by david paul warner on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Posted on Jun 19, 2009
Kerry Degrand
  • 112 Answers
SOURCE: Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Posted on Jul 24, 2009
Brian Anderson
  • 389 Answers
SOURCE: Stihl MS290 only runs if the gas tank vent valve
sounds like you have a plugged vent either in the gas cap or the vent valve of which you speak. Without the vent working properly, the engine running and drawing gas from the fuel tank causes a vaccum inside the tank making it harder for the fuel to draw to the carburator. this would cause the symptoms that you are talking about.
Replace the gas cap if it is vented or check to see if the vent valve you mention is working properly.
Good Luck
Posted on Dec 21, 2009
iain kelly
  • 311 Answers
SOURCE: ltz 250 wont idle needs full choke to run.cleaned
hi,sounds to me like the air fuel ratio is all up the ***,locate the air/fuel screw on the carb(normally on the side)screw the screw right in untill it stops,then back the screw out 1.5 turns,this should get the bike to run without the choke,once you have the bike running simply turn the screw in or out untill the bike settles into a nice steady idle,should be good to go,hope this helps...cheers
Posted on Mar 27, 2010
Anonymous
  • 7 Answers
SOURCE: Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
Posted on May 12, 2010
My troy built riding mower won't run full throttle it only run at about half throttle
if it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Mar 29, 2016 | Troy Garden
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Saw will not rev up to full rpm when you pull trigger it revs up to 1/2 to 3/4 throttle and starts cutting out.
Engine may be too worn or may have run out of oil at some point, compromising the bearings.
May 13, 2015 | Garden
Why does my 8N Ford tractor die at about half throttle?
Sounds like it might be starved for either air or fuel. Have you made sure there is full gas flow from the tank to the carb? Also recheck the needle valve regulating gas flow into the carb. May be that a speck of trash is partially plugging that flow to carb. Should have in-line fuel filter (add on) in addition to the bowl 'filter
Mar 30, 2014 | Ford 8N Tractor
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Trigger stuck on full
This machine has a metal throttle rod from the trigger to the carb, you need to look at the side of the carb where the rod connects to the carb, with your finger ( with the engine stopped ) work the carb throttle spindle manually to see if it is moving freely and it springs back to the small throttle idle screw easily, if it does unscrew the idle screw with a cross head screw driver until the machine idles ok, if not you need to take the l/h side cover off to investigate what has happened .
Feb 02, 2013 | Husqvarna Hand Held Blower 125 B Grass...
I own a Husqvarna 128LD. My trimmer works on full choke, half choke, and when in the run position...it runs...but when the trigger is on balls to the wall throttle, it goes dead. What is my next move?
The next step is to richen the fuel mixture on the H screw on the carb, there is a special tool required to turn the adjuster screws because they have a splinr rather than a screw driver slot, the tool is part np. 530035560 unscrew tthe H screw 1/4 turn anti clockwise.
Aug 07, 2012 | Garden
Sthil ms 192t revs than drops off @wot
Check the gaskets and heat insulator between the cylinder and carburetor base for any leaks or plugging of the impulse pumper air passage. Make sure that a gasket has not been placed in such a way that it blocks this passage. Also, if there is an anti-vibration coupling, it may have cracked the rubber causing an air leak. The engine appears to be running only on primed fuel, but not pumping anything new. Hope this helps!
May 22, 2010 | Garden
Starts and idles and runs half speed ok -- dies off on full throttle fuel lines & filter ok has ffuel in tank good spark & new plug muffler & screen & ports open clean good compression
Since you don't indicate the make and model, I can't give you specifics, but when I had this problem it turned out to be a dirty carb. This can cause uneven fuel flow and loss of power. At full throttle, you may not be getting sufficient fuel to work properly. Try cleaning the carb a nd update this with the results.
Dan
Jan 29, 2010 | Garden
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
