Question about Measuring Tools & Sensors
I have Acurite #75077A1. New sensor new batteries will not talk to inside monitor. tried to resync but no change
Posted by Geneva Hitchcock on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Posted on Aug 21, 2009
Anonymous
  • 133 Answers
SOURCE: remote not talking to console
If your remote is giving out and not allowing you to continue , then yes it could be bad..
But, its hard to tell since you just got the system and the new remote is already bad?
If its not staying in sync, then I would try a different remote before thinking any repair options
Posted on Dec 29, 2009
Anonymous
SOURCE: acurite 1097-rx will not display outside temp or
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
Posted on May 11, 2010
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
SOURCE: New car was synced with garage opener to open from
The process is simple but too lengthy to post here.
Goto homelink.com
They make the system and have very complete instructions you can download.
PLEASE NOTE: MOST but not ALL Brands / models of opener will work with this system.
Note: when you change the battery you need to reprogram the remote.
Posted on Dec 16, 2010
colbary77
Michael Colbary
  • 102 Answers
SOURCE: My Ea Sports 2 heart rate monitor wont sync. I
Open the front of the Wii, you should see a orange or reddish button, push it then push the sync button on the monitor. It should hook right up.
Posted on Jul 02, 2011
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
How do I reset the remote after changing the battery life.
To reset your unit, please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac. Then, follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Feb 21, 2015 | AcuRite Acu-Rite 00754 Wireless...
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Manual for model 00592txr
sending unit is too close , it needs to be at least four feet away from unit
Nov 11, 2014 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
Outside temp does not read new batterys in both inside & outside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Aug 21, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Acurite 1097-rx will not display outside temp or humidity. new batteries. Inside functions normal.
Feb 23, 2010 | Acu-Rite Audio Players & Recorders
Aug 20, 2009 | Nintendo Wii Console
Measuring Tools & Sensors Logo
117 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
