Error code EJ for Glory gfb 500 How do I clear this code?
Posted by Shari Kozminski on
3 Related Answers
Anonymous
SOURCE: Casio PCR_T470 cash register showing error code
1: Turn key to x mode
2: select the electronic journal report by the <rc> key
3: Press the <cash> key, enter start date and or consecutive # and press <cash> key.
Posted on Sep 04, 2009
lbrown1806
Lawrence Brown
  • 488 Answers
SOURCE: Glory GFB 830 note counter
GLORY (U.S.A.) INC.
www.gloryusainc.com
Corporate Headquarters:
10 York Avenue, West Caldwell, NJ 07006
Tel: (800) 999-4510 / Fax: (973) 228-7114
System Product
Engineering and Support Center:
11205 Knott Avenue, Cypress, CA 90630
Tel: (800) 897-1879 / Fax: (714) 897-9415
SALES OFFICES
Eastern Region:
Tel: (800) 654-4564 / Fax: (973) 228-8796
Nevada Region:
2057 E. Maule Ave. Las Vegas, NV 89119
Tel: (888) 439-8262 / Fax: (702) 252-0645
Western Region:
Tel: (800) 762-7824 / Fax: (800) 710-9803
Posted on Nov 26, 2010
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: The error ej on printer lexmark x2600 wont clear
    The EJ error code indicates that your printer carrier has stalled. Try to remove the mechanical jam and press the power button.
    Posted on Apr 11, 2012
    Royal alpha 583cx register... how do I clear and get rid of an EJ full message?
    You usually use an EJ clear code from the manual. This model is rare so I haven't worked with one. Just look in your manual for instructions to clear electronic journal. There is a manual on the net if you need it
    https://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-583cx_instruction_programming_manual.html
    Apr 11, 2017 | Royal Alpha Retail Supplies
    How to clear error 6000 canon410
    Line Feed error or Error Code 6000
    Condition: An error occurred in the LF encoder signal.
    Problems and Solutions:
    • Smearing or scratches on the LF / EJ slit film
      - clean the LF / EJ slit film.
    • Foreign material or paper debris in the LF drive;
      - remove foreign material.
    • If other solution fail, replace one off the following
      - LF / EJ slit film
      - LF / EJ timing sensor unit
      - Paper feed roller unit
      - Logic board
      - Paper feed motor
    Aug 03, 2015 | Canon Pixma MX410 All-In-One Printer
    Casio pcr-t470 electronic cash register has eject full e206 on screen how do i clear this?
    EJ stands for Electronic Journal. The ej is a record of all the sales made on the till since the last time the ej was cleared. If you dont clear it then it eventually fills up and stops the till from working until it is cleared. I dont have a manual for this model but there will be a report to print and clear the ej in your manual.
    Oct 26, 2012 | Casio PCR-T465 Electronic Cash Register
    The error ej on printer lexmark x2600 wont clear and print
    Apr 10, 2012 | Lexmark Office Equipment & Supplies
    Service error 6000
    error code 6000
    Condition:an error occurred in the lf encoder signal
    problem and solutions:
    -clean the LF/EJ **** film. -remove foriegn material. -if other solution fail,replace the following *lf/ej **** film *lf/ej timing sensor unit *paper feed roller unit *logic board *paper feed motor
    May 25, 2011 | Canon PIXMA MP190 All-In-One InkJet...
    Lexmark x2600 is blinking ej
    The EJ error on your printer indicates that your ink cartridge carrier has stalled. Open the printer cover and clear the mechanical jam, then press the power button. Try to reseat your cartridges and make sure it's properly inserted in the carrier.
    Apr 04, 2011 | Lexmark X2600 InkJet Printer
    Glory GFB 830 note counter - kindly can i get the manuals.
    GLORY (U.S.A.) INC.
    www.gloryusainc.com
    System Product
    SALES OFFICES
    Eastern Region:
    Nevada Region:
    Western Region:
    Nov 26, 2010 | Office Equipment & Supplies
    Casio PCR_T470 cash register showing error code E206 EJ Full , you cannont clear it , it just keeps popping back up
    Sep 01, 2009 | Casio Parts Cash Register PC Desktop
    Got the EJ full on my PCR-T470
    turn the key to Z and press RC button until you see EJ clear and then press CASH
    May 05, 2009 | Casio Parts Cash Register PC Desktop
    I'm getting an error code E206 and I can't clear the memory
    To clear the EJ: turn the key to Z, press "RC" until you see "clear EJ", press the "cash" key.
    Oct 07, 2008 | Casio Parts Cash Register PC Desktop
    76 people viewed this question
    Marvin
    Marvin
