Question about Refrigerators
How much ice cube does a polar model PIM15w make, also looking for a manual
Posted by Lenny Wahlgren on
1 Related Answer
Anonymous
SOURCE: polar ice maker model PIM15W
Try Greenwayhp.com look under replacement parts page 3.....The gim15 tray is the same........
Posted on Jun 19, 2009
I have replaced water filter and reset the fridge to just water no ice but its still making ice cubes, but the light is on on the water only. How do I sort it out please.
Hello Carol Eastley,
Sharing your MAKE and MODEL number with
us would enable a beginning for an answer...
ELSE ...
you could look up your refrigerator on
manualslib.com and READ your instruction
manual (owners) from there (or typically
download a PDF image
Just a thought
(if you are really adverse to identifying
your MAKE & MODEL).
Carnac the Magnificent
May 06, 2018 | Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
Polar Ice maker says low water level when full of water
Replace the motor. During the cycle of the unit if the water flow circuit does not scence flow, the unit faults with a low water indication
Jun 22, 2010 | Polar PIM15W Ice Cream Maker
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker don't make ice, the three red lights just keep on blink
Hi, The water tray on the machine is probably broken where it connects to the motor. I have the same problem, and am trying to reach Greenway to see if I can get a replacement part. this seems to be a common problem with this ice maker.
Oct 05, 2009 | Polar PIM15W Ice Cream Maker
Polar ice maker model PIM15W
Feb 02, 2009 | Polar PIM15W Ice Cream Maker
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
