Question about Optics
Why is my dewalt compressor starting up very slowly and then picking up to normal rpm while running
Model number DXCMV5048055
Posted by Rodney Federspiel on
4 Related Answers
Anonymous
  • 10 Answers
SOURCE: i have 1995 Mits Lancer glxi matic. I observed
Try checking the codes. You can do this at part stores like auto zone for free. It might be the maf sensor or if it says lean o2 sensor than it's the fuel filter.
Posted on Jun 29, 2010
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: Model:PFS22MIS AWW S/N LH051463 Freezer
Check to make sure the coils underneath the refrigerator are clean- that's the first thing to check:
  1. Unplug refrigerator
  2. Remove base grille if necessary.
  3. Use a refrigerator coil brush (part number PM14X51) to brush any dust, dirt, pet hair, etc. from the coils. Note: The condenser brush, PM14X51, is 27 1/2 inches long, 12" of which are bristles. Purchase a GE part online
  4. Sweep or vacuum up any dirt, dust, pet hair, etc. on the floor.
  5. Replace grille.
  6. Plug refrigerator back in to the wall receptacle.
Here is what to check concerning the condenser fan:
http://sinkoverflow.net/questions/47/my-fridge-compressor-is-running-all-the-time-but-stuff-in-the-freezer-is-melting
Next thing to check is the thermostat as it explains here:
The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician. Here's how to check a thermostat: http://www.ehow.com/how_2167621_troubleshoot-refrigerators-thermostat.html There is the chance that the unit could be low on refrigerant, in which case it would run constantly, struggling to keep things cold. The condenser fan is controlled by the control board- check to make sure it's running, since the fan itself could be bad. As one of the blogs stated, make sure your evaporator coils aren't iced over (due to a faulty defrost system). So start with the condenser fan- make sure it's running. Check the condenser coils to make sure they're clean. Check the evaporator coils to make sure they're not iced over (indicating a bad defrost circuit). Move the thermostat to see if it makes any difference, and check it if it doesn't have any effect on things. Of course, the dreaded control board could be the culprit, or low refrigerant. If you're handy with a voltmeter, you might be able to determine if the control board is good or bad. Here is a website with your model's diagrams and parts lists: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5230635 Good luck, and hope this helps get it fixed!
Posted on Sep 25, 2010
espressonist
espressonist
  • 1711 Answers
SOURCE: not cooling properly.Freezer items starting to
http://www.fixya.com/support/r6234312-refrigerator_running_but_not_cold
Posted on Oct 01, 2010
Edwin
  • 501 Answers
SOURCE: Jeep Liberty 2002 4x4, While
From what you've described I'm inclined to believe that your fuel pump may be going bad and/or a clogged fuel filter. If you had a bad fuel pump relay it would not crank. If you had a restricted injector/s your vehicle would still start normally but you could have a rough idle or hesitation while accelerating. You can have your fuel system pressure tested to try and check for a bad fuel pump, but if the problem is coming and going it may not show up if your not currently experiencing that problem. Try the filter first, try running a tank of high test and a bottle of isoheet and gumout fuel injector cleaner to see if you notice any difference first. The next step I'd take would be to replace the fuel pump after that
Posted on Jan 22, 2011
How do you replace DeWALT D55154 electric motor brushes?
That model does not have brushes. You can see the parts diagram with this link.
Detail
May 25, 2014 | Dewalt D55154 Heavy-Duty Continuous 4...
I noticed the steel braided hose which is the intake for the air supply is very hot to the touch. Like extremely hot and was just wondering if this was normal? I removed the air filter and tried running...
I believe the hose you are referring to is the "Aftercooler" that connects from the head (outlet) of the compressor head to the air tank. Under normal use, the aftercooler will get very hot. Air is heated when compressed and will heat up this hose and the inlet area of the tank.
Oct 15, 2017 | Dewalt D55270 gas powered air compressors
I have a model 55270 dewalt compressor,serial #20813 I'm looking for manual and age.It shows date 200449-49
The link below takes you to Dewalt parts/service section. Here you will find manual and parts. The dewalt service center will gladly tell you the date of mfg.. Just call them with model, type and serial#. Good luck with your compressor.
http://servicenet.dewalt.com/Products/Detail?productNumber=D55270
Jun 30, 2011 | Dewalt D55270 gas powered air compressors
How to change Emglo air compressor from 220v to 110v. Compressor is running at half speed when plugged into standard wall outlet. I bought the compressor new in the early "90's" and since then...
Hi Pete,
On the side of the motor on the label should be a wiring diagram. The diagram will tell you how to wire fro high 220v and low 110v ...
If the nameplate is single voltage only then the motor cannot be rewired for the lower voltage...
Also check the motor RPM nameplate as compared to the others...you may have a 1725 motor and the newer ones a 3450 motor...that would give them double the RPM's if the gearing or pulley sizes are the same...so.. if you have the right voltage and the RPM's of the motor are the lower, then you possibly could change the pulley sizes to speed up the compressor...
Lots to check and think about...
heatman101
Mar 11, 2011 | Dewalt Air Tools & Compressors
(NEW D55154 COMPRESSOR ) I HAVE TO FLIP THE SWITCH ON&OFF ABOUT 3-4 TIME TO GET IT TO START. WHAT IS THE PROBLEM?
Bad capacitor (or close to going) when you look on the motor is there a cap on top of it that looks like a dome? if it is still under warranty then call Dewalt and see if they will fix it for you.
Mar 04, 2011 | Dewalt D55154 Heavy-Duty Continuous 4...
I have a dewalt emglo electric compressor around 6 months old with only 5hrs of use. i find as soon as the temp drops a few degrees like early morning summer weather it will not start it will turn over...
I have a gas engine powered DeWalt compressor. I don't know about yours, but is there an unloader that you have to switch when you are starting?
Next, did you inform DeWalt, this unit is almost new(ly rebuilt) and they should take some responsibility for it.
You know, it could be that the motor has a starting problem, (bad capacitor, bad start winding system).
Gary
Feb 11, 2011 | Dewalt d55151 factory reconditioned emglo...
Need a manual for Dewalt 4.5 Gal. Electric wheeled portable Compressor
There is 2 types you can find all of the information right here there is part numbers and user's manual.
if it works for you, don't forget to rate me
thx
May 26, 2010 | Dewalt D55146 Factory Reconditioned 4.5...
Compressor question
i have that compressor and had that problem. i build professionally so i use it alot. i had it about a year before the regulator quit working which is what yours is doing. i put it back in the box and took it back to lowes
please rate answer
Feb 01, 2009 | Dewalt D55146 Factory Reconditioned 4.5...
Optics Logo
142 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
