Question about Linksys Computers & Internet
How to fix Linksys Router Setup Error Code 302 ?
Posted by John Martin on
Evan Jose
    Novelist:
    Habit-Forming:
  • Linksys Expert
  • 143 Answers
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: 2wire 2700hg-b wired router wont allow setup of Linksys WAP54G access point
the ip address of the 2wire router might be different from the ip address being used by the wap54g (ip address is 192.168.1.245 by default) that's why it's not being detected.
you need to directly connect the wap54g to a computer and set the computer to use a static ip address (ex. 192.168.1.240) and run the cd that came with the wap54g. you need to set the ip address of the wap54g to the same segment being used by your router to make them see each other
hope this'll help you and just ask me if you have other concern
ciao!
Posted on Aug 26, 2008
Anonymous
SOURCE: Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Posted on Sep 06, 2008
Anonymous
  • 31 Answers
SOURCE: setup problem
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them ....
Posted on Mar 14, 2009
Anonymous
  • 18 Answers
SOURCE: I INSTALLED A TRENDNET ROUTER FOLLOWED ALL
try to return to the manufacturer, cause sometimes a gadgets has a factory defect.... you can return and changes that....
Posted on Aug 31, 2009
Testimonial: "RETURNED THE ROUTER, WAS DEFECTIVE, BOUGHT ANOTHER, INSTALLED IT, WORKING FINE. THANK U"
drpadmanaban
drpadmanaban
  • 32 Answers
SOURCE: Router setup gets Error 302 message
Old configuration parameters are lost. Check with your service operator for a fresh config details to enable the router in gateway mode.
Posted on Oct 19, 2009
How to fix Linksys router error 321 ?
Good day,
This might be of help .
Steps To Fix Linksys Router Error 321:-
Step1:- Check the Firewall Settings
To check the Firewall Settings is the first priority for the users. Then check the firewall settings of the computer/ Laptop, will be helpful to find the problem. If there is any firewall installed on the computer, so the users need to turn it OFF.During the process, the users ensure that the Local Area Connection on the computer is not disabled. The Local Area Connection should not have any static IP address assigned. If there is any then the users need to immediately set the IP address to automatic.
Method2:- Run the Installation CD Again:-
The users require trying to run the CD again and ensure when the CD runs, it will ask to connect the computer and the modem to the router with the cable. So the users will need to notice, that there all the lights lit up on the router. If it's not, then users will need to setup their router without the CD.
The users can get the instruction to setup router manually in the method 3.
Step3:- Try to Setup Router Without Installation CD
Setup Linksys Router without Installation CD is another best option for users in order to completely avoid the in order to fix Linksys Router Error 321.
Follow the below-given instruction to Setup Linksys Router without Installation CD:
First of all, connect the main computer to the Ethernet port on the router.
Then the users need to connect the modem to the Internet port on the router.
Now it's time to verify the status of the light that is blinking properly.
Next, users need to open the setup page of the Linksys Router and then change the Internet connection settings manually.
In the setup page of the Linksys Router, the users can change the settings of the router as per their needs.
Then the default IP address of many Linksys router is 192.168.1.1. And the default username and password would be an "admin".
Wait for a few minutes, when the main computer is able to access the Internet, so users need to create a wireless network for their wireless computers/devices.
or you can call them @ Toll Free 1-800-204-6959 that is Lynksys support.
How To Fix Linksys Router Connect Error Messages?
Which Linksys router do you have? Model number.
What error message do you get?
try to connect the computer to the router with the ethernet cable and login to Linksys router setup page. Check the internet connection settings.
Linksys router login
How to fix error 302
To overcome this, Reset the router from the beginning. Press and hold the reset button for 30 seconds and release the reset button. Unplug the power cable from your router, wait for 30 seconds and re-connect the power cable. Now re-configure your router. Configure the router manually do not use the CD to do it............
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
My ISP uses PPPoE, and we are unable to connect our Wii, to be able to view Netflix. I need to know how to bypass the PPPoE so I don't get the error message from our Wii.
PPPoe shouldn't effect it. You can however ask your ISP to Bridge your port and then you will have to bridge your modem. This is one way to bypass. What is the error message that you are getting? What setup do you have ie: hardwired modem with wireless router, modem only, or combo modem and router in one device? If the error message that you are getting with the wii ask for your PPPoe info you should ask your ISP what your Username and password is for the PPPoe setup. Hope that helps
I have a linksys wrt260n v2 that I've had for about a year. Recently it stopped working when a friend was borrowing it and hasn't worked since. I tried to fix it by resetting it but when i try and set it...
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
When setting up my new D=Link wireless router I get an error message 302 internal error router setup can not continue I can connect on my old router . What does this message mean?
I called the D-LInk support number . The technician was extremely rude and of no help . It was so bad I returned the router to the store and bought a Linksys router. It was easier to install and works great.
1helpful
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
2answers
Open Questions:
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
