Question about Light Office Equipment & Supplies
Bizhub 283 i want copy light and dark in serice mode
3 Suggested Answers
6ya staff
SOURCE:
Bizhubman
Ben
  • 108 Answers
SOURCE: konica bizhub 7272 imprint is too light
First I would try fresh paper from an unopened ****. You could have moisture in the paper.
Some toners have a tape that has to be removed from the toner before installing into the machine. On the 7272 series machine there was a problem with the gears on the back of the developing unit wearing out and not adding toner. The machine would have made a loud grinding/gear skipping noise prior to failure. If this occurred the seals on the developer unit have gone bad leaking developer into the gears and ruining them. The developer and the developer unit will have to be replace.
Another possibility is the Transfer corona wire has broken or is dirty. Open the two front doors, lower the center lever and pull out the transport unit. A little the the left of center you will see some black paper guides, and under those guides are two channels. There should be two hair thin wires in one channel and one wire in the other channel. The single wire is the transfer wire. Make sure it is clean and not broken.
Posted on Jun 15, 2010
Techmind
  • 70 Answers
SOURCE: I an getting light copies on konica minolta bizhub 362 what is the adjustment to make copis dark
Normally light copy comes out when mirrors are dirty. Before any adjustment clean the slit glass and mirrors.
Posted on Dec 18, 2012
Printe black paper
Bizhub C283 or bizhub 283
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 22, 2018 | Konica Minolta Office Equipment & Supplies
Service mode password breaker in km bizhub 283
pass word for admin is different then service which do you want
Mar 24, 2017 | Konica Minolta Bizhub 283 Copier / Printer...
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Mar 22, 2017 | Konica Minolta Konica Bizhub 283 Copier,...
Bizhub 283 won't scan
did you load the new computer with the disk that came with the machine to load the scan software on the computer
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 17, 2014 | Konica Minolta Bizhub 283 Copier
How to reset error code 13 on konica minolta bizhub 283
missing some number on the code code is C-XXXX
Nov 26, 2013 | Konica Minolta Bizhub 283 Copier
Dec 17, 2012 | Konica Minolta Bizhub 362 Copier
Very dark background on copies Bizhub 420
Do prints turn out ok how about the meter read report is that ok? setting are offer in the user mode
Jul 11, 2012 | Minolta Office Equipment & Supplies
Minolta bizhub 222 dark copies
Whenever you ask about any problem please explain in detail.There are couple of reasons behind the above mentioned problem.Its not clear that copies are all black (full black) or just dark in print density? or its giving a dark shade? As per asked question, the solution is Check the followings1-Scanner mirrors are dirty2-Drum is damaged or faulty3-Charging corona 4-LD unit5-Developer
Aug 19, 2011 | Konica Minolta Bizhub 222 Black and White...
26 people viewed this question
Top Light Office Equipment & Supplies Experts
Marvin
Marvin
Copy-Tech
Level 1 Expert
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
