Question about Golf
1970s Harley-Davidson 3 wheel golf cart with Tilston carb with a fixed high speed jet and a t bar low speed adjustment on top of the carb what is the factory settings or base line. Is it 3/4 out or is it 1 1/2 out or could it even be 2 full turns out for low speed setting ? Thanks
5 Related Answers
Anonymous
  • 246 Answers
SOURCE: High / low speed jets both turned into base completely, how many rotations out before fine tuning for performabce.
Hello:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
Anonymous
  • 474 Answers
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Posted on Dec 25, 2009
Anonymous
  • 2220 Answers
SOURCE: will not stay running
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 27, 2010
Repair Ahjoshe
  • 885 Answers
SOURCE: I would like
After seating the screws back them out 1 1/2 turns. This should be close enough to get it started. Let the motor warm up a little then, with it idling, turn the low screw in until it starts having a hard time running then back it out until it idles smoothly. Prop up the Mantis so it can run at full speed safely while you adjust the high side. With the throttle wide open, again turn the high screw in until it starts running roughly and back it out until the motor is running smooth. Some say to turn the screws out until the motor starts having a hard time running and then turn it back in half way to where it was running bad at the other end. This doesn't work as some engines don't care how far open the screws are.
Posted on May 26, 2011
Testimonial: "thanks the settings you gave me got the old beast running again "
mike butler
  • 6468 Answers
SOURCE: craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Posted on Sep 29, 2012
What year is my Harley Davidson golf cart serial number 3B10713J0
Which Model will determine the year...
year serial # model 1984 - 1986 3B G3
1982-83 3B D3
Mar 07, 2018 | Harley Davidson Golf
How do i lean out carb on 2003 dyna
This is done by changing the main jet for full throttle adjustments, adjusting the metering rod (jet needle) clip position for midrange and the pilot (slow) jet for idle and just off idle. There is also usually a mixture screw on the carb somewhere, location depending on which carb, that will also control the low speed mixture. Why are you wanting to lean the jetting. If a carb becomes rich for some reason the solution would be to fix the problem not band-aid it with leaner jetting.
Jan 07, 2013 | 2003 Harley Davidson FXD Dyna Super Glide
When i start the 06 harley fxdi it dies very shortly. i can keep it running with the throttle open or carb cleaner. If i let idle on its on, it will backfire than cut off, can anyone give me some...
If the bike is fuel injected (FXDI), you need to take it back to the dealer and have them take a look at it. There is no "user adjustable" settings on the bike.
May 21, 2010 | 2006 Harley Davidson FXDI Dyna Super Glide
What is the proper way to stat a gas 3 wheel Harley golf cart?
This is pretty normal if this is an old AMF cart...just have to make sure that your battery is is top shape
Mar 09, 2008 | Harley Davidson Road Tech HA90 MP3 Player
Golf Logo
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
