Question about Samsung Office Equipment & Supplies
My samsung C410 printer has an orange light that comes on while the printer is preparing to print. It then just stops and the orange light remains while the printer is unable to function. James
Samsung C410 LASER PRINTER
5 Suggested Answers
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: Brother HL-4040 Laser Printer -- Print Unable 6A Error
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Anonymous
SOURCE: HL-5140 Brother laser printer red status light remains on.
Help me, please . Red status light on. PC recognises printer. Nothing happening. Toner was on for a few weeks. But now new toner cartridge and still solid red light. What is this?
Posted on Apr 29, 2009
Anonymous
  • 161 Answers
SOURCE: I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Posted on Apr 16, 2010
Anonymous
  • 9 Answers
SOURCE: Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Posted on Apr 25, 2010
Anonymous
  • 118 Answers
SOURCE: orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Posted on Apr 29, 2010
C410
Replace Thermistor
May 12, 2014 | Toshiba E-Studio 282 estudio 282
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio C410 bypass tray not picking up and reporting jam
This is happening to me also. The rollers sound like they're turning, but the paper doesn't advance. I then go into th emachine and spin the roller cam a bit and it seems to clear the problem. Any idea what's happening?
Jun 09, 2009 | Ricoh Aficio SP C410DN Laser Printer
How do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This will save you about $50 and less plastic in our landfills. SG
Jan 13, 2009 | Ricoh Aficio SP C410DN Laser Printer
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Jan 03, 2009 | Ricoh Aficio SP C410DN Laser Printer
Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
Dec 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
Paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
Dec 23, 2008 | Ricoh Aficio SP C410DN Laser Printer
Open Questions:
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
