Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
Resize the watch
I would like to know how I can resize the watch. I am not sure if it is with a small screw driver or what else
Posted by isamarah on
Michael Chaffin
  • 183 Answers
If the band is screws then a small screw driver will do the trick. Make sure you use the right size screw driver so you do not strip the screws.
If the band is put together with cotter pins you can push out the cotter pins with a small awl or punch. You want to apply pressure to the end of the pin that is not split or appears to be smooth. Usually when you have cotter pins they are arrows or indicators on the band to tell you which way the pins come out. Make sure you put the pins back the same way they came out.
Posted on Sep 17, 2009
How to resize watch bands with screws.
Yes you do. There is a screw head at the top and the rest is pin. You need a set of jewelers screwdrivers.
http://www.girr.org/girr/tips/tips6/tool_tips/screwdriver_set_small.jpg
Nov 06, 2017 | Bulova Watches
Tip
How to resize a (Casio) watch band
Because there are a lot of questions about resizing watch bands, I thought I'd add a tip how to do it. Roughly two types of links are used with Casio watches, so I've added two how-to video's:
on Mar 26, 2015 | Casio Watches
Montres Carlo. How can I shorten the band?
WATCH BAND ADJUSTMENT / RESIZE - HOW TO - YouTube
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 | Watches
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
Jul 21, 2014 | Timex Atlantis 100 77517 Wrist Watch
Cannot push pins through women's watch clasp to resize. Help?
you dont take pins out of mesh watch bands all you do is put a dart or small screwdriver in the slot to unclamp it slide the clasp were you wont it then lock it in one of the groovs, click link below for instructions please rate me if helped
http://mondainewatch.co.uk/how-do-i-adjust-a-mesh-strap.html
Jan 25, 2013 | Watches
Resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Jan 10, 2010 | Watches
How can I resize a citizen watch with an expandable band? It's a little too big. The owner's manual doesn't tell. Thank you-
If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band.
These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal.
If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
Nov 17, 2009 | Citizen Silhouette Eco Drive Gold Tone...
How To Rezize, by taking out lugs
Not so generic. Either you have to push out small needles in the direction of the arrows that are marked on some links (use a blunt sewing needle to do that), or you can proceed as shown here:
Remove links from metal watchband
Hope that helps
Critter
Dec 26, 2008 | Watches
Beverly HIlls Polo watch needs band adjustment
All you prepare a piece of jewelry screw.There will be very tiny screw in the side of the band you better screw it carefully and when the screw is out detach it,and size it that's you like size comes out.That all if want to resize desame what did in the other side. Always do it slowly so there no scratch or visual impaired damaged.
Jun 16, 2008 | Beverly Hills Polo Club 22-710TTS
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
207 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Marvin
Marvin
Are you a Citizen Watch Expert? Answer questions, earn points and help others
