Looking for belt that ejects cd holder from player for a Kenwood DP-M4010
Posted by Ray Gutierrez on
3 Related Answers
Anonymous
SOURCE: stuck disc in JVC CD player
It wasn't a car cd player, but a component for a stereo.  I took off the case and shook the player until the disc dropped out.  We plan to replace the player, so no further help is needed.  Thank you for getting back to me so quickly.
Posted on Jan 12, 2009
Anonymous
  • 91 Answers
SOURCE: Have a 6 disc cd player in a BOSE 30 Lifestyle
May i suggest you try selecting each of the 6 CD's then depress each of these buttons waiting about 10 seconds between each press - play, stop, eject. You can also try powering off the unit between each press. It may be the microprocessor that send the commands to logic circuitry to perform the next mechanical funtion. It isn't necessarily something that you did wrong. It could simply be an electronic failure.
Posted on Jul 04, 2009
CJ Withers
  • 183 Answers
SOURCE: 2003 gmc envoy slt cd player takes the cd hums then ejects the cd displaying check cd . it looks like the cd never fully seats into the player before it ejects it. how do i fix it
Same problem on my 04 Silverado, then it stopped ejecting them. I had to replace the stereo.
Posted on Mar 04, 2017
The cd cartridge in my Kenwood multiple player DP-M4010 was put in at an angle rather than strait. Now the cartridge is jammed. How do I open the back of the player to access the CD drawer
I think you should buy repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will get something useful here Best Manuals
Dec 21, 2017 | Cars & Trucks
Cd gets stuck in recorder makes clicking sound..
I would just guess that the belt that is in the eject mechanism is now stretched- That is if there is a belt. That is very common in all CD player units.
Feb 12, 2015 | Tascam Dp-02cf Digital 8-track Recorder
Kenwood DP-R892
May be a broken belt. See if the turntable lifts out. There may be a circlip that holds it in or turn the player upside down taking care with the arm not to damage it. If the base comes off you may be able to see the belt. They are usually only the size of a skinny elastic band. If your turntable is a direct drive ( No belt) the motor may have failed.
Jun 27, 2014 | Kenwood Audio Players & Recorders
Does not play has e22 on display on my kenwood dp-m6010 disk player
On the kenwood dp m6010 6+1 cd player, the e-22 and e-21 codes are for the laser head movement limit sensors. More than likely the drive belt is broke or stretched.
Jul 27, 2013 | Audio Players & Recorders
I have a stereo Integrated Amplifier KA-7010, Multiple Compact Disc Player Dp-M4010. It was a gift from my brother and he cannot find the exact cables that came with the system, and I have a pair of...
More triage first.
Which unit cuts off? Signal Cables won't make either do that. Either will run just fine even without them.
CD players die.
http://www.repairfaq.org/sam/cdfaq.htm
Speaker issues or shorts will pose problems for the amp.
Do you have the manuals? If not, seek them.
Jul 06, 2011 | Kenwood Audio Players & Recorders
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
My kenwood dp-r99 reads ee
I just took my DP-R99 out of the closet and powered it up in my garage. After a short delay it reads EE. I took it apart and the belt that drives the laser head up to the CD and pressure disk to make it spin is slipping and never raising the head enough. It looks like the belt has stretched over the years. I am now going to look for a replacement belt and the belt that rotates the carriage since it is also stretched. I will let you know for sure when I install new belts. Hope this helps...
Jun 06, 2009 | Kenwood CD-206 5-Disc CD Changer
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
64 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
