Question about HP Computers & Internet
Hello Does the HP T730 take a 2" core size - HP Computers & Internet
Posted by Julie Petrin on
I have a Proliant HP DL580 G4 that had its system board replaced. The OS (Windows 2003 Enterprise) now only recognizes one cpu core. The server has 4 dual core cpu's. How can I get the OS to see all 8...
You may need to check your BIOS to make sure the multiple CPU function is enabled. Once it is, a reboot should correct this for you.
Good Luck
C2Solutions
Sep 08, 2011 | HP Compaq ProLiant DL580 G4 (430811001)...
We want to purches a laser printer for printinhg legal size paper,which printer we use
Hello
You can any of HP laser Jet with your budget for legal size printing, all printer can print legal size printing, however there are some printers for quick reference.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
Dec 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hello my laptop having unable to startup problem.repair program at the startup unable to fix the startup problem.window goes blank.circular window icon don't pop up.even after format.problem still...
if you can see some msg after power on then screen and CMOS BIOS is OK...
try changing the CMOS battery inside....(battery model will be CR2032 i guess so...it will be aprox the size of a dime(US 10 cent coin size)
or
RAM is corrupt...change the RAM cards inside...ensure that the new RAM is compatible...
pls leave a feedback...
reg
May 09, 2010 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Hello sir, m a student of b.tech nd m searchng for a laptop of hp pavellion in range of 44,000.i want config(dual core/core 2 duo,3GB ram,180/250 harddisk bt screen size 14.4).DV5 is nice one bt screen...
I recommend that you get a laptop with windows xp, its more stable than the versions of vista, but if you like vista you could get a hp pavilion tx5-1218 those are pretty good
Dec 13, 2008 | HP Compaq Presario F750US
Hp system board
the machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Dec 08, 2008 | HP Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
