Sc-pm19 will not stop cycling through display messages and will not go to any function. What procedure shall I follow?
Posted by George Pollick on
4 Related Answers
Anonymous
SOURCE: CD135 phone answerphone function has stopped working
Hello, I have the opposite problem. I'm trying stop the answering machine so I can use the one that comes default with my phone line.
If anyone can help, please email me on [email protected]
Posted on Mar 14, 2008
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Panasonic SA-PM19 - insert CD
Hi me2you
Your machine is not reading the disc. This can be caused for several reasons. The cd players lens may have a film of dust preventing it from reading. Try a lens cleaner CD. This is about the only thing you can do without getting into the internals of the unit. If you are electronically savvy, I can talk you through some more diagnostics, but generally this will mean replacing parts to fix the unit. If the Lens cleaner does not fix the problem, you may need to take the unit to a Panasonic repair guy for a quote. .
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 03, 2008
k24674
  • 8091 Answers
SOURCE: Can not display the graphs of functions
I have a manual in another language than English, so I do no know exactly or remotely what procedure you refer to, but I have recreated an instance where one gets the error you talk about. I give you the picts.8147bde.jpg When I enter [Diamond][Graph] I get the following message.
The graph independent variable is x by default, yet I entered cos(f). The calculator is expecting a function of x and I give it a function of some as other entity. Hence the error message. On the command line you cannot change the argument of Y1. It is x by default.
Hope it clarifies things.
Posted on Sep 13, 2009
hotpoint jon
  • 353 Answers
SOURCE: Two minutes after starting a new cycle, the washer
maybe using too much powder try less
Posted on Jun 28, 2010
Ride height specification for 2002 Bravada and procedure on replacing sensors.Or where can I look on line for this information.
Air Suspension ??????
Air Suspension Description and Operation
Air Suspension
The primary mission of the Air Suspension System is the following for the rear suspension under loaded and unloaded conditions:
• Keep the vehicle visually level
• Provide optimal headlight aiming
• Maintain optimal ride height
The Air Suspension System consists of the following items:
• Air suspension compressor assembly
• Air suspension sensors
• Rear air springs
Important: The Air Suspension System must have a voltage supply of at least 12.6V to operate properly.
The Air Suspension System will maintain the rear D height within 4 mm (0.15 in) in all loading conditions and the leveling function will deactivate if the vehicle is overloaded. The side to side D height variation is maintained within 8 mm (0.31 in). After ignition is turned off, the air suspension control module (ASCM) will remain active for between 30 minutes and 2 1/2 hours. The system will exhaust pressure within 30 minutes after the ignition is turned off to lower the vehicle after unloading. In a temperature-controlled environment, the leakage of the complete load leveling system will not result in more than 1.4 mm (0.05 in) drop of rear suspension height at GVWR during a 24 hour period. If the outdoor temperature drops from +20°C (+68°F) to -5°C (+23°F), the rear D height may drop as much as 25 mm (1 in). However, the Air Suspension System should return to the specified D height when the ignition is again cycled to ON.
What is the problem ?
Diagnostic Trouble Code (DTC) Displaying
The Air Suspension system has an internal clock to prevent overheating if the compressor assembly is running for a prolonged period of time. If the system overheats, all leveling function stops until the system cools down. During this time, the indicator LED on the air inflator switch will be quickly flashing at a constant rate.
The other three diagnostic trouble codes are displayed with a blink code on the inflator switch LED. The Air Suspension Compressor Assembly shall begin to indicate the code when the condition to cause the code becomes current.
The number of the fault code shall be represented by the number of flashing pulses on the inflator switch LED. The flashing pulses shall have a repetition rate of 0.5 seconds and each code shall be separated by a 3.0 second delay. All codes shall be flashed in the order of occurrence of the fault. The blink code shall take priority over other processes that have access to the inflator switch LED. Refer to the following:
• DTC 001
• DTC 002
• DTC 003
Trim Height Uneven or Low ??????
Feb 24, 2017 | Cars & Trucks
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
Apr 12, 2016 | Ricoh Office Equipment & Supplies
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
How reset oil change light 2011 charger
Your vehicle is equipped with an engine oil change
indicator system. The "Oil Change Due" message will
flash in the EVIC display for approximately 10 seconds
after a single chime has sounded to indicate the next
scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style.
Unless reset, this message will continue to display each
time you cycle the ignition to the ON/RUN position. To
turn off the message temporarily, press and release the
MENU button. To reset the oil change indicator system
(after performing the scheduled maintenance), perform
the following procedure:
1. Without pressing the brake pedal, push the ENGINE
START/STOP button and cycle the ignition to the ON/
RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Without pressing the brake pedal, push the ENGINE
START/STOP button once to return the ignition to the
OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Source: Owner's Manual page 293
Dodge Charger Owners Manual
Oct 04, 2013 | 2011 Dodge Charger
Reset oil change indicator on 2011 Dodge Charger
within 10 seconds.
OFF/LOCK position.
Oct 22, 2012 | 2011 Dodge Charger
I have a Panasonic CD Stereo Shelf System, Model SC-PM19. When I am playing a CD, after a few minutes the entire units shuts off and "F61" flashes for a moment on the screen before total...
F61 is generally a 'shorted-speaker' or 'microprocessor' problem.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 30, 2011 | Panasonic SC-PM19 CD Shelf System
Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
May 29, 2009 | Ricoh Aficio 450 Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Feb 28, 2006 | Panasonic SC-PM19 CD Shelf System
Marvin
Marvin
