Question about Sharp Televison & Video
My sharp tv 55 inch less than a year old keeps cutting out. only with cable and fire tv and fire stick.
Posted by Samantha Gibbs on
5 Related Answers
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 03, 2009
Chi Chu
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Frigidaire Gallery Fridge freezer keeps
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 08, 2011
Steve
  • 3289 Answers
SOURCE: Can i connect my Sharp flatscreen tv to my wifi
Ron, in order to connect your TV to your home network, it will need an network interface. A network interface can be either a wired network jack on the TV itself, or a built in wireless capability (WiFi). You didn't provide the model number of your particular Sharp TV, so I can't tell you if your TV offers this connectivity or not.
Even if your TV offers wired or wireless connectivity, some TVs only allow network access to update firmware or to display "still" JPEG or GIF images; not to stream audio or video. The TV will need to have some sort of player to display or play video and / or audio files. Even then, if the TV is not fairly new enough, it may lack the support for newer file formats - such as .MKV, MPEG, etc. that are used for a large number of HD content.
You can get around this hurdle by connecting a newer computer to the TV. Purchase a wireless keyboard & mouse and connect the computer's video card to the TV so that it will appear as a monitor to the computer. Make sure your get a video card in the computer that will provide a digital video output - (HDMI, DVI, etc.) and a cable that can plug into one of the unused A/V inputs on the TV. If using a cable other then HDMI, you'll need to provide a cable between the computer's audio output and the TV's audio input. Use the computer's network interface to download or stream a program directly to your 55 inch "monitor".
I hope this helps - good luck!
Posted on Nov 14, 2011
TV just flashes different colors I have a sharp aquos 4K 55 inch I bought like 3 month ago and keep flashing color blue, red ,white , green what should I do ??
I would at this point send it back. It has a year warranty. The problem is most likely the inverter but like I said, return it for a replacement.
Jul 10, 2016 | Sharp Televison & Video
Samsung Curved Tv screen went black, how much will it cost to fix?
If set is less than a year old it is covered by warranty. Otherwise it is gonna cost more than what you want to pay for a relatively new set!
Feb 04, 2016 | Samsung UN55HU8700 - 55-inch Curved 4K...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
My new Sharp tv only displays in monochrome
It should work. You may want to try DVD player or play a VCR tape to be sure that it is the TV. If it is the TV and it is brand new from a retailer, I would take it back for a exchange.
If they will not exchange it, get in touch with Sharp and find a local Servicer that will repair it
under warrenty.
I hope this helps,
Skyassoc
Jul 25, 2009 | Televison & Video
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony wega 61 inch (odessa, tx)
TV is a Sony WEGA 61" model # KDF-E60A20
May 28, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Apr 13, 2007 | Sharp 32C241 TV
Open Questions:
Televison & Video Logo
32 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
