Question about Electronics - Others
Hello, is there a replacement or equivalent ic to used instead of TA1319AP ?!
Posted by Ahmad Dalbani on
1 Related Answer
Anonymous
SOURCE: Need equivalent IC
i made programmer for 89c51. in this use ic ds275. i want know what is the equivalent ic of ds275.
Posted on Dec 06, 2008
Hello.I need a circuit diagram or technical manual for the Carrier HK50AA020 Module.fault---red and green led not flashing,always on.Thank You
How did you know those were bad? You had to have something to test them and that would tell you what to expect. I used google with this: Carrier HK50AA020 manual and got several hits.
Dec 19, 2014 | Televison & Video
Replacement of another equivelent ic TDA9340PS/N3/A/1923
Which IC is equivalent as-- TDA9340PS/N3/A/1923(NXP).
Feb 12, 2014 | LG Flatron L1750S 17" LCD Monitor
My IC BT9843 is burnt I need an equivalent to replace it.any help please?
Try searching again using Google, using BT 9843, but when you look down the results ignore the two letters and see if you can find an IC which is the same numbers, even if it has different letters on the front. Those letters could be just the makers letters, with the device made by different makers.
Aug 14, 2012 | Creative Labs Audio Players & Recorders
Samsung ln40a530
Hello
Check the retifier diode for 5VDC for short. If it is OK, replace the regualtor IC [5VDC], if used.
Mar 01, 2012 | Samsung LN40A530 40 in. LCD TV
Replacement of LA7830
You can replace the LA7830 linear integrated circuit with any of the following parts:
Replacement part type / code
1508-07003A-00
ECG1773
IX0640
KA2131
NTE1773
SK9752
I've found the replacement parts in a specific website that allows you to find replacements for integrated circuits and semiconductors: http://www.icreplacements.com
Complete information source for your reference: http://www.icreplacements.com/L/LA7830-replacement-compatible-Linear_integrated_circuit-substitute-equivalent-part-cross-reference.htm
Hope it helps.
Jul 10, 2011 | Televison & Video
Hello, My main color were out of alignment, as per instruction on manual. I pressed the button for digital array and proceded to align the blue color, then I proceded to align the red color but I could...
The red convergence IC has failed. There are I believe 3 total convergence IC in your tv. The prefix for all three is STK392-xxx. If you can solder you can try and replace yourself otherwise you need a tv tech. With Hitachi's sometimes some critical resistors will change value as well and have to be replaced with exact equivalents. Sorry wish it was an easy solution..
Oct 17, 2010 | Hitachi 55FX48B 55" Rear Projection...
I have a 50" projetion toshbia the blue will not line up on the bottem there is also a curve i would like to know if it is worth fixing or can it be fixed and can i do this by myself and what part i could...
Hello: Seems your convergence IC's have failed. These are two large IC on the Main Powersupply board. Have both replaced as a preventive measure.
If you are good at unsoldering and soldering componet IC's then yes you can do this yourself.
The IC are STK-392-110 but use 120's instead.
Oct 20, 2009 | Televison & Video
Need equivalent IC
Aug 10, 2008 | LG F-185 CD Shelf System
Electronics - Others Logo
155 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
