Question about Car Audio & Video
How do you set up the PHUD15 in your car? - Car Audio & Video
Posted by Thomas Tompsett on
Set clock for mercedes clk 320
go to setting and choose clock setting, pushing the button up and down until the correct time, then the clock will turn automatically to match the digital clock you set in the setting.
Apr 18, 2013 | 2005 Mercedes-Benz CLK 320
Samsung GT C5130 connect to my car (mazda) but can't talk
I would check the settings on the phone. Some phones have various settings and it seems like your phone settings is still set to pick up via Bluetooth headset - check the answer settings and you should be able to change it to in car settings. Which will allow the car Bluetooth to pick up the call.
Jul 16, 2012 | Samsung GT C5130 Mobile
Car moves in reverse while parking brake is set
put car in reverse, while rolling set parking break, this will adjust the shoes out, to hold it. Be sure not to set it too many times it will lock wheels down.
Sep 28, 2017 | 2004 Mercury Grand Marquis
Heater & defroster works fine but inside car windows keep fogging
So you have the vent settings to blow out of the windshield vents and still have fogging?
You can dry out the air more quickly if you use the air conditioner setting. It sounds backwards, but this is exactly what the manual in my older car said to do. (Some cars are electronic control and won't let you do this however - or they do it automatically with the defrost vent settings).
For the older car, I would set the heat to the hottest setting and press in the a/c button. The a/c dries out the air, but it does not have to be set to run cold.
Another thing that could help is to make sure that you do not have the vents set for "recycling" the air. The picture should look like a u shapped arrow. Make sure it is not pressed in.
Dec 20, 2011 | 1999 Oldsmobile Alero
Timing settings
U are taking about the car timming belt setting?Yes,this u can't do those setting it correctly without a laser light timming gun,take to a auto mechanic paid the fee an he'll help u set ur car timming belt setting correctly into position.
Oct 03, 2011 | Cars & Trucks
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
How do i set the clock? I have tried many ways that i have been told and none work.
Welcome to FixYa!
Here is how to set the clock.
Initial Settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press M.C. and hold until CLOCK SET appears
in the display.
3 Turn M.C. to select the initial setting.
After selecting, perform the following procedures
to set the initial setting.
CLOCK SET (setting the clock)
1 Press M.C. to display the setting mode.
2 Press M.C. to select the segment of the clock display
you wish to set.
Hour-Minute
As you select segments of the clock display, the
selected segment flashes.
3 Turn M.C. to adjust the clock.
If you need the manual you can get it in the link below. page 11
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-2200UB_OwnersManual0922.pdf
Good Luck
Nov 09, 2010 | Pioneer DEH2200UB with iPod Direct Control...
We reinstalled our Evenflo car seat and now baby's head flops forward. How can we fix this?
First check the settings on the car base. Usually there are 3 settings so most likely the setting you adjusted it to is too high for your baby. You have to remove the baby form the car seat (smile), check the setting level (at the front of the car seat) and adjust accordingly. Good luck i hope this helps!
Aug 20, 2009 | Evenflo Embrace Deluxe Infant Car Seat
How to set the clock
IT IS STUCK ON DEMO AND CANT SET THE CLOCK
Jul 22, 2009 | JVC AM FM CD DET FACE CAR STEREO
I can't set the time on my car stereo
See if this works:
you have to press and hold the set button until you see "demo" appear, and then RELEASE the set button - this gets you to the settings menu.. Then you use the little >> and << selector to select clock hour /then clock minute and use the tuning dial to adjust. - then push the set button again to exit the settings menu.
May 31, 2009 | Kenwood Car Audio & Video
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
