Question about Locks & Locksmithing
How do I set the combination on a new Garrison combination cable lock?
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
Garrison
The manufacturer has a video for installing the electronic deadbolt, it might be helpful.
https://www.youtube.com/watch?v=UZ0nsArpesc
English vision
https://www.youtube.com/watch?v=SqAP2Jgd9n8
French vision
Should you still experience difficulty, please return to your store.
by
CanadianTireTeam
- CanadianTireAnswers
1 month, 2 weeks ago
May 18, 2014 | Locks & Locksmithing
How to set the combination on a Blackburn ANGOLA COMBO CABLE LOCK
Open the lock using the original combination, which was 0000 for mine. Once open, you will find two tabs on the lock side--on top and bottom of the lock portal. Push in both tabs, and hold them down while you set the new combination. Once it is set, put the post back in to make sure it is still open. Twist the dials to lock it, and then you should be able to unlock using your new combination.
Feb 23, 2014 | Bell Blackburn Angola Combo Cable Lock
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
Post. (Figure 1)
etc.
original position.
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Locks & Locksmithing Logo
270 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Chris Walker
Chris Walker
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
