Question about Inverter Electronics - Others
After disconnecting the motor from the output terminal of keb f5 servo and start only the inverter the display error e.oc still occur. what will I do next
Posted by Ukoli Abel on
3 Related Answers
Anonymous
SOURCE: F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Posted on Apr 11, 2010
mntech1
  • 120 Answers
SOURCE: F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Posted on Apr 01, 2014
mntech1
  • 120 Answers
SOURCE: Fcon in keb f5
Forward CONtinues
System is at the commanded speed in the forward direction.
Apr 01, 2014 | Inverter KEB COMBIVERT F5
E oc in f4
Error Over Current.
Disconnect motor leads at U/V/W terminals and run the inverter to determine if the problem is internal or external of the inverter.
If it is external then you are looking for a shorted winding in the motor or a shorted motor lead between the inverter and the motor.
Mar 05, 2014 | Inverter KEB COMBIVERT F5
E OC error in F4 KEB
Error. Over Current - Peak current exceeded
Possible causes:
Motor has a short - Phase to phase or phase to ground.
Motor cable damaged/defective.
Motor cables too long.
Acceleration/deceleration ramps too short.
Damaged output phase of inverter.
EMI
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Feb 12, 2014 | Inverter KEB COMBIVERT F5
Need a Way to adjust dr.2 Rated Motor Current value. Combivert F4-C
It sounds like you may have a thermal issue causing the fault trigger of the E.OC error. This coould be an issue with the motor or the inverter getting too hot. Once the system trips into error it is allowed to cool a little and you can run again for a while.
What is the actual part# and serial # of the inverter that you are having problems with?
Since they system has been running, I would not suggest aultering the voltage/hz curves in the inverter because of an E.OC error.
Dec 28, 2013 | Inverter KEB COMBIVERT F5
Eoc alam
E.OC is an over current error.
The inverter is sensing a short on the U/V/W terminals. This could be a shorted motor, motor leads and an internal short in the inverter.
Disconnect the motor leads from the inverter, and run the inverter as you normally would.
If the E.OC error does not occur the short is external of the inverter.
If the E.OC occurs, then the short is internal to the inverter.
Nov 26, 2013 | Inverter KEB COMBIVERT F5
E.up and eoc always occurs,what the problem?
E.UP = Under voltage
Check your supply voltage.
E.OC = Over current
Check for shorts between the inverter and motor.
Feb 19, 2011 | Inverter KEB COMBIVERT F5
I have a prblem in the F5 keb combivert it's show Error E.OC & E.puci & E.Puch could you please advice us with the proper solution thanks
E.puci During the initialization the power circuit could not be recognized as invalid.
E.puch power unit changed
power unit identification was changed, with a avalid power circuit this error can be reset by writting to SY.3. If the value displayed in SY.3 is written, only the power-cricuit dependent parameters are reinitialized. if any other value is written, then the default set is loaded . On some systems after writing SY.3 a power-On -Reset is necessary........
E.OC Overcurrent
Apr 11, 2010 | Inverter KEB COMBIVERT F5
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
What does the error EdoH mean
Over temperature signal from motor temperature sensor. Error can only be reset once the display reads E.nOH. Causes:
*Resistor at terminal T1:T2 > 1650 ohms * Motor overloaded (getting hot) *Temperature sensor defective
Aug 18, 2009 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
171 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Anon
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
