Question about Panasonic Televison & Video
Can can Amazon Prime Canada be added to my 60" panasonic plasma with viera connect circa 2008 - 2009
5 Suggested Answers
Anonymous
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Posted on Oct 31, 2007
livetech
  • 583 Answers
SOURCE: Panasonic 50" Viera plasma on/off problems
its the problem in main board.any of the capacitors or ic are getting overheated that needs to be checked and replaced. thanks.
Posted on Jul 13, 2009
Doldog
  • 222 Answers
SOURCE: how to connect sound bar
Does your TV have an Audio out? If it does then you can connect it from there.
Posted on Jun 12, 2010
Kevin Penn
  • 1139 Answers
SOURCE: I cannot connect my Xbox
Please try the following solution to reset the display :
1. Turn your console off.
2. On the Xbox controller press and hold the "Y" button and the right trigger.
3. Turn the console on using the Xbox guide button on the controller, NOT the power button on the front of the console.
This should now reset the display back to standard and you should be able to set your video up properly.
Hope this helps and thank you for using FixYa
Posted on Jan 06, 2011
ladywinn
ladywinn
  • 5138 Answers
SOURCE: My 42" Panasonic Viera Plasma
What is the model number printed on back of TV?
Posted on Feb 27, 2011
Panasonic viera plasma 60 tv. Ethernet hooked directly from router to tv, how do I put router password into tv.
The router password will be asked for when you try to connect by the TV if the thing is picking up the WiFi signal.
Jun 24, 2017 | Panasonic Televison & Video
My viera tv kicks out of netflix as a show is loading, any suggestions?
Try to sign out and sign back in again. Was having the same issue (I think. Was getting "Cannot play title right now, please try again."). Called Netflix support and this was their solution. It worked great, havent had an issue since.
Jan 30, 2015 | Panasonic 60" VIERA Plasma 1080p HDTV -...
How do I load my amazon prime app onto my Smart TV. It's a Panasonic Viera, internet connected.?
A TV isn't a computer in the way that your tablet is. So the range of apps that the TV can host is limited. If the Amazon Prime app isn't available or 'addable' from within the Viera set-up menus then the TV won't support it.
You could look at using a casting device with the TV to add extra functionality. The obvious choice would be Google Chromecast. This will give you the apps you have on the pad available on the TV too.
Sep 17, 2014 | Panasonic Televison & Video
How to connect viera link
What is Viera Link? Viera Link allows the control of other Panasonic home AV devices via the television remote control.
By pressing the Viera Link button on the television remote, it is possible to turn on and navigate the menus of other Viera Link equipment. Please note, Viera Link requires an HDMI connection between the television and the external source.
More control functions have been added with each new generation of Viera Link compatible products. However, it is important to note that the newer functions only work if both products are from the same year of manufacture. Therefore, if an older source is used with a newer year of television, only the older functions common to both years will work.
Aug 26, 2014 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic service manuals
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Panasonic TCP60S30 60 Class Viera Plasma...
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
CONNECTING THE SET TO MY SURROUND SOUND SYSTEM.
What surround sound system can I buy to go with my panasonic viera th-50px80u plasma tv. One where I can here sound from cable and bluray
Jul 03, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Televison & Video Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
