For TGA470, one of the 4 phones had the ring turned off. Now I want to turn it back on.
Do you mean the Panasonic KX-TGA470 handset? The KX-TGA470 handset is the included handset for several models of Panasonic cordless phone systems, including the KX-TG7732. When the ringer is off, the handset should show a bell with a line through it. To adjust the ring volume, press Menu on that handset when the phone is in standby. (The base and handsets are not in use.) After pressing the Menu button, type # 1 6 0. (Alternatively, use the arrow keys to navigate to Initial Settings and press the soft key for Select. Navigate to Ringer Settings and press Select again. Go to Ringer Volume Handset and press Select once more.) Use the arrow keys to select a value between 0 and 7. 0 will keep the ringer disabled. Press the soft key for Save. Press Off to exit the menu.
You can also adjust the ringer volume on that handset by pressing the Volume Up key while the phone is ringing at the base and other handsets. You can adjust the base ringer volume by pressing the + or - keys when the phone is ringing. Alternatively, press Menu # * 1 6 0 from any handset. Note: this phone system also has a silent mode. Press Menu # 2 3 8 to enable or disable the feature. When this is enabled, the handset will show an icon with several Z's.
You can find the manual on the phone system page: https://shop.panasonic.com/support-only/KX-TG7732S.html . The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg7731_mul_om.pdf . See pages 23 and 35 for the ringer volume adjustment. See pages 35 and 40 for information on the silent mode.
I hope this helps.
Posted on Oct 14, 2019
Oct 11, 2014 | Cell Phones
Mar 15, 2012 | Uniden Cordless Phone
Jul 09, 2011 | Uniden Cordless Phone
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Apr 06, 2010 | Uniden Cordless Phone EXAI985
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Aug 29, 2009 | Uniden DECT 6.0 Cordless Phone ID
Mar 25, 2009 | Uniden Cordless Phone
Dec 05, 2008 | Nortel Meridian M26 Corded Phone
124 people viewed this question
