Question about Optics
Sighting in VX R Patrol 3-9x40 after bore sight
Posted by Steven Fandrich on
5 Related Answers
Anonymous
SOURCE: Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Posted on May 18, 2008
Anonymous
  • 75 Answers
SOURCE: how to sight scope in /what scope do i have ?
Real simple Scott.
You can 'Zero' your scope/rifle even if you don't have a laser bore-scope device.
All this is assuming that your used rifle has not had the barrel shot out and that the head-space is still within specs for that rifle. Have all this checked by a gunsmith first. You can dress up a piece of poop and it will be pretty, but still be poop. Make sure yours isn't to begin with. As for the scope, it's hard to tell unless there's obvious damage or it's an antique past it's prime. Try to get as good a quality scope as possible to start with. You would not put one ply tube tires on your mustang and expect to get the best performance, so...
Most rifles are capable of shooting quite accurately, and all things being equal, it's the shooters job of making it happen.
Ammunition should be considered as well. Toss your old military ball ammo and junk from overseas, both of'em. If you want to shoot accurately and consistently, you must spend the bucks for the best ammo you can afford.
You MUST KNOW what the BALLISTICS are for the Cal./type/weight ammo you will be shooting and the corresponding distance it will be shot from.
Make sure your rifle is CLEAN inside and out. A clean rifle is a happy rifle.
Make sure that your rifle 'fits' your body's frame and that you are familiar and practice good rifle shooting techniques.
'Zeroing' is best done from the prone position as that is the most steady position to shoot from.
Do you have a bi-pod attached? Whether you do or not, sandbag your rifle securely but still able to make small adjustments to the rifle position itself.
Set up a target with a 1" black dot at 50rds.
Remove the bolt.
Lay down with your rifle but stay OFF of it, touch it as little as possible at this point.
With out disturbing the rifle look through the bore downrange to your target. Locate the black dot and if necessary adjust your rifle from the **** end until you can see the dot through the bore. Keep making minor adjustments until the dot appears to be centered in the bore. Make sure rifle is secure and steady at this point.
Then without moving or touching the rifle, look through the scope using the correct eye relief distance and locate the black dot. Now using the Vertical(Elevation) and Horizontal(Windage) adjustment knobs, move the reticles(crosshairs) until they both are centered on the dot.
Again look through the bore to make sure that you have not moved the rifle and that the dot is still centered in the bore. If not, adjust the rifle again to center the dot, then go back to the scope and adjust as necessary to move the RETICLES to the center of the dot. It may be necessary to repeat this a few times before you have achieved this particular goal.
You do not mention brand/model of your scope. It probably adjusts the reticle or crosshairs in 1/4minute increments (1/4 inch increments with each individual click movement of the turret knobs at 100 yard distance). IT IS CRITICAL for you to know how your own scope adjusts.
Now, bolt back in and load 3 rounds of quality ammo.
You are going to shoot 3 rounds in succession without getting off the rifle or making any adjustments to the rifle or scope. You are looking for a 3 shot group to determine a rough average of how far and where the rounds are impacting initially. Use good shooting techniques, breath control, relax, sight picture, squeeeeeeze the trigger, follow through the scope, there is no need to take your eye off the scope while doing this, hold your shooting position for all 3 shots.
You will now have to make adjustments of the scope unless you are hitting the black dot already which is quite possible.
Remember that if your scope is a 1/4" adjustment at 100yds, it means that for each 'click' that you adjust either Vertically or Horizontally at 100rds, the reticle/crosshairs will move accordingly 1/4 of an inch Vertically or Horizontally. At 200yds, one click will move it 1/2 inch, at 300yrd it will move it 3/4 of an inch, at 400yrd, it will be 1 inch.
Right now you are at 50yrds distance from your target. Each click from here will move the RETICLES about 1/8 of an inch so estimate the distance that your most central shot of the 3 you fired, is from the black dot and adjust accordingly. You're not moving the RIFLE here, you are simply moving the scope RETICLES so that your point of aim and point of impact coincides.
Now load 3 more rounds of ammo and repeat as above. You should only have to use about 9 rounds to get on target, the black dot.
Once you are hitting the black dot at the 50yrd line, move back to the 100yrd line. Put a fresh black dot on your target and repeat the steps from above. Your first 3 shots from the 100yrd line should be about 1/2 to 1 inch low. Don't follow the bullet strikes! Keep your point of aim and the crosshairs ON the black dot no matter where the bullets are striking on the target. Remember, now at 100yrds your RETICLES will move 1/4inch with each 'click' of adjustment of the turret knobs.
Adjust the scope as needed at this point. Once you are 'ON TARGET'(hitting the black dot), you now have your 100yrd. 'ZERO'.
Now that you have this 100yrd ZERO, you must loosen the turret knobs , both the Vertical(Elevation) and the Horizontal(Windage) turrets and align the '0' on the knobs with the '0' on the scope at the base of each knob. Now tighten the set screws and you are set to go. If you want to know your 200yrd 'ZERO', simply move back to the 200yrd line, your 'come-up' or elevation adjustment should be about 7-9 clicks, at least for .308 168grn HPBT, but you will figure it out for the Cal./brand/wght ammo you are using. WHATEVER the 'come-up' you need to make at 200, 300,400yrds or wherever, be sure to make note of the number of clicks you used to find the Zero for that distance. Use a fine point endelible marker and actually write the ZERO info on thestock of your rifle. You don't need to mark anything for the 100yrd ZERO, it's a given already. Write; 200/9, 300/18 and so on. You should also get your ZERO for the intermidiate, 150yrd, 250yrds etc, distances as well.
Remember that weather conditions, source and intesity of light conditions, your own body condition at any particular moment or day can have an affecf on how you and/or your rifle shoot. Good luck.
Posted on Apr 21, 2009
Anonymous
  • 75 Answers
SOURCE: windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Posted on Apr 28, 2009
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: What is the best way to sight in a simmons scope
the way i tell all the club guys it to clamp the gun down tight, fire a round into a card at say 20yds then and with out moving the gun at all,,,,adjust the cross hires untill there dead over the hole the round made in the card,,, then move the card back to say 50yds the round will shoot high so look for it, but it should be in line with the card,,,just adjust the hight then,,
Posted on Nov 18, 2009
Mark Campeau
  • 44 Answers
SOURCE: sight adjustments
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that very same spot.
To move the scope's reticle up or down, turn the elevation adjustment on the TOP of the scope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
If you want to move the direction the scope is looking left or right, turn the windage adjustment on the RIGHT side of the scope left or right to look where the bullet is impacting. To move the crosshairs to the right, turn it right.
Hope this helps, Mark the Gunsmith
Posted on Dec 30, 2009
I have a savage 110 270 win.i put a nikon buckmasters2 4x12x40 on it im trying to sight in at 50 yards i looked it up it says to sight in at 50 yards it says -0.14 i do not know what that means
The only way to sight in is to bore sight or use a bore sight laser
then put rounds down range at the target to get the point of aim and point of impact to converge
Dec 03, 2016 | Nikon Optics
How to use redfieeld 3x9x42 scope
Depends on the scope and rifle type to which it is attached.
I invested in an inexpensive laser bore such as this one for an AR: SightMark AccuDot Laser Bore Sight - 223 Model SM39001 (for AR-15)
Once the scope is mounted properly, and assuming you have not made any vertical or horizontal adjustments, set the rifle on a stable platform, insert the bore sight, point it at a target 50 (rimfire) to 100 (AR) yards out (works best in low light situation).
Once you have the laser centered on your target, make elevation and windage adjustments as necessary placing the scope cross hairs over the laser. Remove the bore sight and fire 3 rounds, then fine tune elevation and windage.
Dec 27, 2014 | Optics
I have a Bushnell Bore Sight with multiple adapters for various calibers, I have been looking for a bore sight for the 17 HMR, is there one available for the set without buying the entire set?
You can buy a laser bore sight that looks like a bullet that shoots a laser out. You just load it like a bullet and then sightyour scope to match it at the proper yardage. If you can remove the action(like with a bolt action) then you could just sight down the barrel(with the rifle in a gun vise) and then adjust your scope to point at the same thing you see through the barrel.
Jan 22, 2011 | Bushnell Laser Rifleshotgun Scope...
How to sight in a z6 swarovski scope 10x42
the easy way is bore sight it,,,,,first clamp the rifle in a stand and look down the barrel at some thing like a post top at say 100 yds when you see the post top in the bore dont move the rifle any more till you have tweeked your scope so the cross is on the top of the post top,,,the rifle is then bore sighted,,,now clamp the rifle down and test fire it,,,it will likley shoot low,,,so tweek it till it shoots right,,,,you should get it spot on in less than 5 rounds,,,dont try to hand hold your rifle when zeroing,,,you need to get rid of as many wobbley bits as you can,,,gees whats the bigest wobbley bit?,,,,yep we are? so clamp it down till it shoots right! also dont fire more than 5 shots or you will get your barrel hot and this changes the point of aim,,,in a sporting rifle???
Nov 27, 2010 | Swarovski Optiks Z6 Riflescope
I purchased the scope from US. After mounting to a Tikka super varmit I bore sighted it using a Bushnell Bore Sighter. I have been unable to get the elevation to 600 metres as it stops at 400 metres on...
easy this one!!!! undo the eye end of the scope and slip under the scope 3 strips or so of 35mm film then nip the scope back down this will lift the point of aim well above what you need,,,
do your self a faver though,,,throw away that bore sighter,,,and bore sight the scope at 100yds first,
but clamp the gun in a gun vice when sighting it in,,,,you need to get rid of all the wobbely bits first?
gess whats the bigest wobbley bit,,,,yep,,,,,you are!
Oct 06, 2010 | Nikon 624x50SF Matte Nikoplex Monarch...
I aser bore sight my Bushnell banner. I need to
if it is verry tight back it off a little bit you dont want to break the seal.i have never been a big fan of the laser bore sighters.i have had a cpl and both were inaccurate.BSA makes a good bore sighter for 49 bucks.try a cpl shots with it and find out how far you are truely off.remember 1 click is 1/4 inch.in 100 yrds.in the army we had all the ammo we needed to sight our rifles in.but here in the real world with ammo prices so high a good bore sighter is the way to go.
Oct 19, 2009 | Bushnell Velocity Speed Gun
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
I am trying to bore sight a rifle with a center point 4x16x40 and i run out of adjustment to get the lazer to align with the cross hairs
When bore sighting you need to adjust in small steps and "TAP" the bore or the main body of your scope to cause a golt, as when shooting your gun it will kick and cause the scope cross hairs to take their set.  Tap it with a med sized screw driver handle. Make a small adjustment and tap it, adjust and tap.
Sep 23, 2009 | Centerpoint Technologies CenterPoint...
My wife has a Ruger Mini-14 patrol rifle with the
If your wife wants to use it for defense and, etc have her cowitness the optic 4moa sight with what Solution #1 suggested, instead of the normal position of the optic. Co-witnessing optics is better suited for quicker reactions, snapshots with the pekiti take off "advanced version of getting off the x"
Sep 15, 2009 | Optics
Optics Logo
127 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
