Question about Tablets & eReaders
Is not connecting to my ipad - Tablets & eReaders
Posted by Diane Wile-Brumm on
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
My ipad says ipad disabled connect to iyunes
You should try to connect the iPad to your computer, open iTunes and see what it need to do. You probably need internet connection, and should back up if possible.
Aug 16, 2014 | Apple iPad 32 GB 3G Tablet PC
I can't connect to ITunes
connect the pad to your computer and open iTunes, turn off the ipad, then hold both the lock and the home button for 10 seconds, then release the lock button while continuing to hold the home button until iTunes recognizes the iPad.
iOS Device not recognized in iTunes for OS
Jun 18, 2014 | Apple iPad Tablets & eReaders
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Jan 28, 2014 | Apple iPad 16 GB 3G Tablet PC
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
Oct 15, 2012 | Apple iPad 32 GB WiFi Tablet PC
Comcast ipad wifi problem
I'm sure you've done this but try turning off wifi on iPad and then turning back on. Does your wifi name show?
Jun 17, 2017 | Apple iPad 32 GB 3G Tablet PC
IPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
Feb 22, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
327 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
