Question about Refrigerators
Americana rm 2652 fridge was fine in 5th wheel. Moved 5th wheel and now fridge does not come on to cool and freeze. Eyebrow board also does not light up.
Posted by Shirley O'Mara on
5 Related Answers
MARLON KELLER
  • 111 Answers
SOURCE: How hard is it to
make sure the rf is not sitting on the legs but setting on the wheels. it is very common for installers to roll down the legs to stabilize the machine in order to prevent liability issues or simply just to level the rf due to unlevel floors
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 20, 2008
Joe Hogan
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
Anonymous
SOURCE: my check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Posted on Jun 07, 2009
mexifin
  • 24 Answers
SOURCE: everything freezes, model 2652 dometic
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Posted on Sep 24, 2011
SOURCE: I am looking for a light bulb for Dometic
any hardware store will carry that bulb
Posted on Sep 30, 2011
Everything freezes, model 2652 dometic americana
Sep 14, 2011 | Dometic RM2652 Refrigerator
N621 does not cool or does not turn off/on with the button The lp lights fine but the compressor does not seem to be getting cool.
Eyebrow board or control board is bad. kI just had one like this and it was the control board. The compressor shoiuld not get cool. The entire back of the fridge will be hot. You need proper air flow for the back to cool properly. That will cause all kinds of problems as far as cooling.
Aug 10, 2011 | Thetford Norcold® Model DE0061
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Have a dmetic rm 2652, have power in fridge but no freezer or cold in fridge,tried restarted 3-4 tims still no good,trieda new 5 amp fuses ran 3 minutes stopped again?
On most Dometics, When you have a cooling problem follow these steps and it will resolve your problem or at least tell you what is wrong.
Check main terminal Block for proper Voltage
Check Heating element for proper ohms, 2652 is 44ohms
Disconnect P-2 wire on board for approximately 12 to 18 hrs. This makes the unit run constantly in case there is a clog in the unit.
The only other thing you may do is check the thermistor operation, Unplug the P-2, remove the thermistor from inside the refrigerator, put it in ice, You want the thermistor to drop to about 32 degrees, Check the ohms, they should be at 8,000 to 10,000 ohms.
If all checks out, you have either a bad board, not common, or a bad cooling unit, common
Jun 11, 2010 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
How hard is it to remove the dometic americana 2652 double door fridge?
Jun 20, 2008 | Dometic Refrigerators
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
