Question about Kenmore Dryers
Sears Kenmore dryer blowing only cold air, reset breaker and same results.I have a electric dryer, 110.61202011
Posted by Jaime D Yslas on
TJBeckwith
  • 35 Answers
Your heating element is probably bad. Recommend if you are going to dyi, spend a little extra and buy the housing with element already inserted. You can buy the elements alone, but of you don't install properly, they will expand when heated and short out on the housing and send you back to square one (learned this one the hard way).
Posted on Oct 13, 2019
Tom Chichester
    Top Expert:
  • Kenmore Master
  • 56,040 Answers
Failure of heating element(s) or control circuitry
5 Related Answers
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
dealt_soul
James Bradburn
  • 299 Answers
SOURCE: blows only cold air
Check connection to heating elements. My have bad heating elements
Posted on Jan 19, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
dray8165
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
Dryer tumbles,blows cold air no heat,looking for access to fuses,dont know what part of dryer fuses are located
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Sep 28, 2010 | Dryers
I have a gas dryer that has a bad thermostst how can it be replaced Do 110 dryers use more electricity than the 220, are they safe
The thermostat is located in the back, behind the back panel and mouted on the air discharge from the drum before it entered the blower that blows it out via the vent. They are normally snap-disc style thermostats and can be ordered from sears parts direct online or purchased at most sears appliance parts stores. Gas dryers also have at least two over-temperature devices to prevent an overheat condition that may lead to a fire. One is normally a snap-disc thermostat (some with a manual reset) and the second is usually a thermal-fuse that must be replaced...not reset. 110 gas dryers use a lot less electricity than 220 electric dryers since all they have to do is turn the drum and blow the air (heat comes from a gas flame) where the 220-volt electrics have electric heating elements that comsume large amounts of power. Yes, I would consider then safe as long as they are vented correctly.
Nov 27, 2009 | Kenmore 63942 Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
My kenmore dryer is blowing out cold air
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
My dryer is just blowing cold air
Check the breaker box make and make sure the breaker is all the way over to the on side and then if it still continues check the thermal fuse and the heating element.
Apr 01, 2009 | Whirlpool LER4634J Electric Dryer
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
147 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
