Question about Magnavox Televison & Video
Magnavox tv no longer works from remote controls
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Replace the batteries in the remote, then push a button next to an FM radio, you may hear a buzz, that tells you the remote is working,this test doesn't always work,by the way. Next, turn the TV off & unplug for 10 min
Posted on Oct 12, 2019
Testimonial: "Nothing wrong with the remote, its the TV that is not responding."
5 Suggested Answers
oldnovii
Jeffrey Pemberton
  • 667 Answers
SOURCE: Remote control
Hi chief - go the following link. It will tell you exactly what you need to know. If this solved your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a great day.
http://157.254.235.130/public/IBRCR350REVB.pdf
Jeff
Posted on May 03, 2008
Anonymous
SOURCE: How to Auto tune remote control for 1993 Magnavox
I have an older RCA universal remote control and a magnavox tv from 1993. According to my universal remote user manual (which I found online) I punched in a three digit code: 062 that worked for me, for my 1993 Magnavox TV: hope this helps!
If not, here are some others to try from my RCA universal remote user manual for Magnavox tvs---
004, 006, 008, 019, 068,069,074,075,076,077,088,089,130,131,132,133,134,183,184.
Posted on Oct 02, 2008
Anonymous
  • 160 Answers
SOURCE: Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Posted on Dec 02, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Posted on Apr 18, 2009
Anonymous
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Why is the remote no longer functioning?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 16, 2015 | Magnavox Televison & Video
I need a remote for my television
This link will assist you with getting a remote that will work with this television.
http://www.replacementremotes.com/PHILIPS/Buy-996500015582-Remote-Control.html
Mar 29, 2011 | Philips Magnavox 27MS343S 27" TV
Need code for programing a phillips magnavox with a direct tv remote
i need help to program the phillips remote control sru8112 i no longer have the codes can u help me?
Oct 03, 2010 | Philips Magnavox Learning Universal Remote
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
SDTV REMOTE CODES FOR MAGNAVOX
Hi
On the URC 4330 model the Magnavox brand is not listed in the code index.
Therefore, you should be aware that this remote may not have code stored in its pre-programmed library to allow it to operate Magnavox.
There is a code search function with this remote and this is your only other option in a situation such as this.
TO SEARCH FOR YOUR CODE FOR YOUR TV
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first so this may take some time to complete.
5.Once you find the point at which the remote operates the TV press and hold SET until the LED blinks twice, then release SET. This locks in the code.
As I say - the remote may or may not compatible with Magnavox. However this search function is there to use in situations such as this.
Hope this helps. Thanks for using FixYa.
Jan 09, 2010 | One For All URC-4330 Remote Control
I have a RCA Universal RCU430-needcode for Magnavox TV
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jun 03, 2009 | RCA Universal Remote Control
Remote control
Try this website, "www.remotes.com"
Apr 25, 2009 | Philips Magnavox Learning Universal Remote
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Jan 14, 2009 | RCA RCU404 Remote Control
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
29 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
