Question about Refrigerators
Where is the control panel reset button for the flat screen computer on the Samsung frig. Our screen lock is on and we cant get the touch screen to work
Posted by judy yankowski on
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: How to clean a Samsung flat panel TV screen?
Only with the cleaning cloth provided....
Posted on Jul 31, 2008
Anonymous
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Posted on Dec 20, 2008
IQUIT
  • 3940 Answers
SOURCE: Blue Lock in the middle
http://support.dell.com/support/edocs/monitors/E152FP/En/controls.htm
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds
Posted on Mar 24, 2009
Anonymous
SOURCE: Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Posted on Sep 30, 2009
Anonymous
SOURCE: My samsung tocco lite's touch screen has stopped working
mines is the same and i can still anwser to any number and only make calls to the last person i spoke to and also i can take pictures all the buttons work and its fine apart from the screen also my reseption is really bad on this fone iam trying to sell mine for spares and repairs and iam thinking about buying onw without the touch screen next time its rediculas
Posted on Apr 22, 2010
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
Samsung reset password i cant reset my settings because i forgot the password
hi,
you can reset your phone even you did not know your password by doing this tricks....
on the phone lock screen call SOS then press the call button in the screen, from there you can enter full reset code *2767*3855# then wait for the phone to restart and your phone code is gone...
i hope it will hep you ,thanks for trusting fixya
Jan 30, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Have a 16" dell flat screen monitior. The display are very dim,and make for hard viewing. Tried to push buttons on computer but a locked icon flashes up. Tried holding the buttons to unlock but did not...
You need to hold the menu button for 15 seconds until the lock icon changes to unlock. Then you should be able to adjust the brightness of the monitor, assuming that the backlight is working properly. Hope this helps you.
Jul 29, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
I hold the lock key down to unlock my phone and i still cannot touch the screen for my samsung instinct
hi :) if make sure when push the button for unlock,the button have function. still cant touch screen,maybe your touch screen was spoil already. just send for technician exchange.
Jul 06, 2010 | Samsung Instinct Cell Phone
I forgot password of my touch screen samsung omnia
I think you'll have to hard reset your device, in order to get passed the password request procedure. You, most probably, know that a hard reset will return your device to its factory defaults, thus deleting all the applications you have installed, as well as all your personal data and settings. Anyway, to hard reset your device, press and hold both the SEND and END buttons, and, whilst keeping them pressed, press the reset pin with the stylus pen. Release the keys when a confirmation request screen comes up. Follow the on-screen instructions (if I'm not mistaken, confirm the hard reset procedure by pressing the SEND button).
Hope you are able to have a fully functional device again soon.
Best regards, Carlos
Jun 21, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
The touch buttons are locked How can i
Try my instruction here:
http://www.fixya.com/support/r4616564-samsung_lcd_monitors_lock_unlock
if it does not work with your model, then you need to go to SAMSUNG website and down load manual for your model.
http://s807.photobucket.com/home/budm/allalbums
May 08, 2010 | Samsung SyncMaster 943BM Flat panel TFT...
Touch Screen Problem
check all the buttons on control panel if one is stuck it will lock them all just push all of them acouple times. if they all click then your panel screen may need to be replaced
Dec 16, 2008 | Canon imageRUNNER 2200
Auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
Mar 02, 2008 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
