Question about Video Cameras
How to open cc617 camcorder to load tape belong to grandparents never used one before
Posted by Lillie on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: Tape refuses to load
needs to be sent in theres a problem with your chassis its very easy for them to do that they are very sensitive its not your fault it just happens.
Posted on Nov 19, 2007
Anonymous
SOURCE: loading tapes
Hello, exact same problem here, closes fine when no tape inserted, but with a tape, the camera won't close, just keeps ejecting the tape.
Another problem that I encountered is that the camera will not take pictures anymore.
When I press the button, it beeps, but there appears a green dot on the screen,
My handbook tells me, when this dot appears on the screen, this means he camera will not take a picture, it however doesn't tell me how to solve the problem.
Anybody
Posted on Jan 05, 2008
nil420
SOURCE: cant put tape in camcorder
Then remove the tape and check it in another camcorder.....
............. Very simple.
If the tape works fine in another camcorder then throw this camcorder. Let me know the location where you will through it.
Posted on May 08, 2008
Anonymous
SOURCE: RCA CC617
Had the same problem took mine apart and found the ribbon cable going to the viewer was cracked and broken probably because of the flexing of the cable during adjustments. Not fixed yet.
Posted on Oct 17, 2008
Anonymous
  • 62 Answers
SOURCE: JVC Camcorder Tape door stuck
michanical dis arrange inside the tape socket
Posted on Mar 20, 2010
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
1helpful
2answers
Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
2answers
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
2answers
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
2answers
RCA CC617
probably the lcd screen is broken (the one that you can see through the veiw finder) if this is the case it is not reasonably fixable. Otherwise it may be a connection that is broken and it is not getting any feed. If you give it a little tap and it comes to life breifly, this is probably the case. You can take it to a small electronics repair shop and they will let you know if its worth fixing or just using as is.
1helpful
2answers
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
1helpful
7answers
Tape won't load
Was having a similar problem but the tape would not even partially load. Spent several hours, over the course of several days trying to figure how to fix this and found the following solution to a similar problem on this site. I tried it as a last resort...it worked! Now I just need to figure out what to tell my wife when she asks me "how" I fixed the camera???? Here is what I did...I allowed the mechanism to close without a tape inserted (the only way it WOULD close), gave it a solid - but gentle - whack on the tape side of the camcorder with the palm of my hand...sort of like burping a baby. I said a little prayer to the saint of hopeless causes (St. Jude Thaddeus)...slid the open/eject button, opened the door, slid a tape in, gently pushed it down (where it says "push") and ...the mechanism closed!!! Not sure if the "fix" will last but we'll see and report back if the problem crops up again.
Picture rolls on playback
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
The cassette holder isn't closing......and the tape is not loading
not geting in holder tht mean u must open ur casset holder and put in polethin bag for a hour and it will accept tape
Video Cameras Logo
Top Video Cameras Experts
Harrie
Tony Parsons
Tony Parsons
Are you a Video Camera Expert? Answer questions, earn points and help others
