Question about Garden
How to put on a chain
The chain came off of the Model 1400 WEN chainsaw. How do I put it back on
Posted by Beverly Westgate on
5 Related Answers
Anonymous
  • 360 Answers
SOURCE: chain not engaged when the chainsaw is running and brake is off
NOT FOR THE FAINT OF HEART....with the clutch cover, chain and bar removed, start the saw. with a gloved hand, hold the clutch and squeeze the throttle. if the sprocket engages/turns...its not the clutch.
let me know what you find.
clarkco
Posted on Apr 29, 2009
Dwain Pippen
  • 376 Answers
SOURCE: ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Posted on Jun 11, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: wen electric chainsaw chain gets loose
There is a nut on the rail that the chain runs on. You can loosen it, pry the blade out so chain is snug, than tighten it while you are prying.
Posted on Jun 22, 2009
drallim
  • 4088 Answers
SOURCE: chainsaw lubrication
Use regular bar oil available almost everywhere, not motor oil.
Posted on Jul 04, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: I have a 1400 wen chainsaw and need a replacement
It is listed here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
HTH
Lou
Posted on Oct 17, 2009
Tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
Nov 05, 2011 | Electric Chainsaw Sharpener
Do you have in stock a chain adjuster for a Wen Lumberjack electric chain saw, model number 6016?
Howdy, we are not a parts provider, but rather a problem solving and question answering service. I have located the customer service number for Wen tools so you can get your part as soon as possible.
Here you go:1-800-232-1195
Thanks for using FixYa.com
Regards, Farmerbear
Sep 07, 2010 | Electric Chainsaw Sharpener
Hello, I am trying to find a user manual for my husband's latest bargain find...a Wen 10'' electric chainsaw - Model 5010 - has Hornet Mark 1 on label - also, where can I go to purchase extra chains for...
How about one slightly newer (6018)? I was not able to find a match for your model. Wagner purchased Wen some time back and have since stopped production.
WagnerSprayTech
http://www.wagnerspraytech.com/portal/finding_a_product_manual_spray,98115,747.html
If you take your existing chain to a local chainsaw seller/mechanic a replacement can be fabricated. No chain? take the entire saw and bar.
Your can create a part number here:
I came up with "91VG041G" HTH
Lou
Dec 09, 2009 | Garden
Where can I find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
Aug 26, 2009 | Electric Chainsaw Sharpener
Chainsaw lubrication
Jun 30, 2009 | Electric Chainsaw Sharpener
Wen electric chain saw manual, where do I find one on line?
Wagner purchased Wen long ago and no longer offer chainsaws. Try these, if they can't help we can't either.
WagnerSprayTech
WenProducts.com
http://wenproducts.com/
Lou
May 07, 2009 | Electric Chainsaw Sharpener
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
