Question about Maytag Washing Machines
Maytag Bravos XL washing machine: After a couple weeks of erratic blinking and sounds (washing cycles worked fine) the machine will not turn on. Control board replaced, did not help.
Posted by Mike Buschman on
2 Related Answers
dyronwebb
Dyron Webb
  • 220 Answers
SOURCE: does a maytag bravos washing machine have to be recalibrated after a new electronic control board was installed?
Most do instructions should have come with new control
Posted on Feb 20, 2015
Testimonial: "The new control did not come with one. Do you happen to know what to do?"
choulroy
Charles Houlroyd
  • 124 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
Remember its whats inside that maters - I will never ever again buy another Maytag! Bearings are a disaster in the top loaders.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Posted on Mar 22, 2015
My 2016 Maytag bravos XL MCT showing error code F5. Is this a simple fix?
Lid lock error. They are explained here:
https://www.searspartsdirect.com/washer-repair/error-codes/maytag-bravos-mvw-top-load-washer-error-codes.html
Oct 12, 2018 | Maytag Washing Machines
How long should it take to run a clean washing cycle
On the high efficiency machines it takes longer, because of the amount of water used. It takes a few more cycles to complete.
Mar 04, 2015 | Maytag Bravos XL High-Efficiency Electric...
How to replace drum bearings on a maytag bravos xl washing machine?
Not just the bearing, you need the rear tub assembly and basket in case the shaft is damaged
Aug 19, 2014 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
I have Maytag Bravos washer, which displays an HC code at the end of the wash cycle. However, it has been working fine for months, and the hoses are in the correct places. What should I do?
Apparently your hoses are switched, it means you rinse cycle is pumping in hot water instead of cold. Turn off the water to the washer, switch hoes connections to washer or the wall, not both. This should fix the problem..
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 15, 2011 | Maytag Bravos MVWB400V Washer
Washing Machines Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
