Question about Water Water Heaters
Red light on WR1 Receiver is constantly flashing
I still have hot water and heating comes on
Posted by Alison Ruth Robert on
4 Related Answers
Anonymous
SOURCE: red light flashing on
More information is needed.
Open following link to help identify your gas valve and access error code.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment and say which gas valve matches.
Then add what code is blinking for possible help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 31, 2011
Anonymous
SOURCE: red light is flashing on
You have tank-type water heater, but type of water heater and control is not known.
For possible help, add a comment and say if you has gas or electric water heater and describe what type of gas valve or control box is giving the error code.
Open following link to identify some basic types of controls:
Posted on Jul 08, 2011
Gene Haynes
  • 5391 Answers
SOURCE: not hot water or heating
Good luck with the repair.
We always stand ready to support success.
Also post the brand and model number and type of product so expert can identify if you have electric or natural gas or propane energy, and identify if there is basic information online about your product.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 30, 2012
Mike Pym
  • 168 Answers
SOURCE: thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but th
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Posted on Mar 05, 2013
I have a Worcester 24di combi boiler and it's not working I have a red flashing tap light have represurised the pressure but still not working I have no heating or hot water can you help me please
Red flashing lights usually mean trouble.
There is not enough air getting to the combustion chamber, or the chimney is not working properly. (Stopped up flu)
If this is not a pretty obvious problem, it is better handled by someone who knows a lot more about it than us.
Feb 26, 2016 | Water Water Heaters
Water heater is not firing up
Faulty gas valve,contact a gas safe engineer to replace.
Sep 27, 2017 | Water Heaters
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Mar 05, 2013 | Water Heaters
Not hot water or heating
Aug 24, 2012 | Water Heaters
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Oct 18, 2008 | Water Heaters
Water Heaters Logo
175 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
