Question about Power Computers & Internet
The power adaptor of an old SimpleTouch SimpleDrive ext. HDD USB2 died. Its output specs say 12V, 1.5A, 18W max. I found an old one that says 12V, 1.2A, 14.4VA Max and it worked. Can I keep using it
The HDD was working fine for several minutes: what am I missing in terms of performances if I use this power adaptor regularly?
Posted by Max Taverna on
5 Related Answers
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Posted on Jun 23, 2008
Anonymous
  • 505 Answers
SOURCE: power cord
Best Option is to replace with a 12v adapter cord
Posted on Sep 16, 2008
Anonymous
  • 113 Answers
SOURCE: Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
Posted on Jul 25, 2009
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: Dear Sir, I have astec model
possible that you need a lot more wattage try a heavy duty one
Posted on Aug 14, 2010
Anonymous
  • 57 Answers
SOURCE: ISO 400 Power Supply 300W Description
Acquire a replacement power cable simialr to the one missplaced.
Posted on Dec 22, 2010
Lost power cord
I believe that you would be ok. Voltage has to be "Spot on." Amperage, however, needs to "meet or exceed." Think of Voltage as pushing something into something. Think of Amperage as pulling something out of something. It won't draw more amps than it needs, even if they are available. Allow me to thank you for including the powerpayless website as until your post I didn't know what voltage I was looking for. Exactly the same thing happened to me with my SimpleTech 1TB. Perhaps we both solved eachother's problems. PS: I'm going to check with Radio Shack for a 12v adaptor with at least 3.5 Amp capacity. They might can beat the $30.00 which is what the above mentioned place gets including shipping.
May 16, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
Power supply
I THINK THERE IS NO POWER ADAPTER COMES WITH THIS DIVICE IT ACTUALLY PULLS IN POWER FROM USB U JUST NEED TO FIND THE POWEWR CABLE FROM THE USB .
Dec 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
Changed internal harddrive and now, computer cannot recognize the simpletech pininfarina external hard drive
If you loaded a driver for the Ext HDD with the old HDD, simply reload it or download off the net.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Hercules ProphetView 720 Power Adaptor Polarity
Yes the adapter must have an output of 12vdc AND rated for a least 4.0A output!
Dec 29, 2008 | Scanport 821S 17" LCD Display Monitor
NEW SPECIFICATION:
  • INPUT 100-240 V
  • 12VOLT AT 6 AMP.
Jun 23, 2008 | Protron PLTV-32 Television
Computers & Internet Logo
16 people viewed this question
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
